1993 Corvette Burning oil, whining.....
Does anyone know what would be the cause of this whine?
I figured it's time for a rebuild with how bad the oil is burning (rings/gaskets/bearings??). But identifying what causes this whine would be helpful.
Thanks everyone.
Thanks everyone.
Given the smoke from DS...something not happy on bank 1. Probe around motor with a stethoscope to see if you can isolate a cyl.
I suspect a plug read may also reveal what cyl, if not more, are fouled/rich.
compression check
A guess from this side of the internet...broken rings
any metal flakes in oil??
compression check
Honestly, this engine is getting rebuilt at this point.
Just wondering if anyone knows what would cause the whining noise. I'm thinking cam bearings? Maybe oil pump (pressure is good).
I really think the smoke is bad rings, the smoke gets worse as rpms go up. So does the whine.
Nah, if it broke the law, itd be prosecuted........
Why the super high idle? Have you checked into that as well? Given the high idle coupled with the smoke, its possible that the lower intake manifold gasket on the driver's side could have given up the ghost and the car is sucking in oil from the lifter valley. That would account for the idle (massive vac leak) and the smoke (oil). Put a vac gauge on it and see what it says.
I believe almost 100% this is the problem. The Owner just informed me that the P.O had issues with the intake manifold lining up after they did some head work.......
He also has the brake book hose hooked up to the valley PCV line instead of the intake plenum. LOL. Anyway, I asked if his brake were really hard, he said no. Yet another thing that points to an internal vacuum leak from the valley.
So, I started her up and pulled the oil fill cap, see the results below.
I'll be pulling the intake manifold to see what needs to happen to fix this.
What i find weird is that my heads are worked over by LE (P&P, shaved, etc.) and didn't have this issue. Hopefully it's something simple....
Holy smokes. I've never seen vacuum like that through the valve cover! Well, here's hoping you're on the way to sorting it out.
If the heads were milled incorrectly, the angle between the intake manifold and the head could be off, and it may never seal using regular gaskets. All hope is not lost, though. You can get thicker intake manifold gaskets from SCE. A .090 thick intake gasket is $26.91 or a .125 thick gasket is $ 34.60.
