Need To Siphon Out Old Gas
http://www.partsreloaded.com/PWC/Acc...oY0aAuWk8P8HAQ
No luck what so ever. Now im doing the Trap Door method next week for changing the fuel pump and my question is would I be able to siphon out the gas through the hole that way or is there another way of doing it? The gas is about 1 year old and has become stale.
You can also run a fuel hose to the Schrader valve on the fuel rail and put the other end into a gas can. Then you can use the hotwire plug under the hood to manually turn the pump on by connecting a wire to the fuel pump relay plug on the passenger side by the pcm ---this will turn on the fuel pump relay and allow the fuel pump to run while the car is off. You can just run a direct wire to the plug from the 12 volt red box/battery or put a momentary switch in between to turn it on and off easier.
How much gas in the tank and how old is it?
I have 3/4 of a tank of 4+ year old gas. I also have a Walbro pump with the sock along with a 5 year old fuel tank. I don't recall any anti siphoning device. But if there is one and I have to use the fuel pump to get the gas out will the crap gas clog up the sock?
