Need help. Chatter won't go away
That's the whole story, ANY help will be greatly appreciated. I will accept criticism as long as it's constructive.
I'm not sure if there is a wrong way to put the windage tray back on but I will take a second look at that when I remove the intake again.
your sound does sound "internal" more than valve train but your lash procedure is not right so you need to deal with that first.
I would do the engine off method starting with #1 cyl at TDC and do 1/2 the valves then rotate engine 1 revolution and do the other 1/2. Go buy a Haynes service book for your car which explains the procedure. You don't need "timing marks" to find TDC. You rotate the engine by hand watching the RR movement. When #1 is TDC you can do both intake and exhaust valves for that cyl. There is a specific order of what intake and what exhaust valve you do when #1 is TDC. Just refer to the service book for the order. Once you do the valves with #1 at TDC you rotate engine by hand one revolution bringing #6 to TDC and do those valves. You do both intake & exhaust on #6 when it is TDC and the various intake & exhaust valves noted in the sequence the book will have.
You find zero lash by screwing in the RR poly lock with your fingers while moving the PR up & down until there is no more up/down movement. It takes a VERY light touch with your fingers in screwing down the poly lock to get to zero lash. Then turn poly 1/2 turn and lock it. Move on to the next valve in the procedure sequence.
You can't tell if your rods are hitting the windage tray by pulling the intake, you need to pull the pan. If you have a 383 and run the stock windage tray you need to stand off the windage tray 1/8" from where it was stock or the rod bolts will hit it. The motor will make a major knock if you don't and you would know this IMMEDIATELY on first start up if that was not done. You just put a 1/8" thick washer on the 3 long main cap studs and also between the tray and oil pump to raise it away from the crank/rods
SSRRR note about the starter changing speeds during crank does suggest the valves are not closing on some cyl which is why I suggest confirming and re-doing the valve lash. This would resolve the issue of valves not closing and that cyl losing compression....but if knock is from below....motor tear down will be needed
Ideally the valve lash will resolve the problem....but from the sound of video there may be deeper issues
As far as the windage tray I have not pulled the motor since it was built and it has about 10k miles on it. It has always has a slight tick near cylinder #8 but I never found it to be a problem. I raced it hard. It may have been the beginning of this problem but like I said it went a long way that way.
Compression test results are in...
I appreciate everyone giving me there thoughts. I'll continue to post here once I found out more.
