LS1 brake upgrade?
FWIW, I did the LS1 brake upgrade a couple years ago and needed the following parts: LS1 spindles, LS1 calipers w/brackets, rotors, pads. I used the factory LT1 brake lines which were more than long enough (my car is lowered quite a bit which helped, may not be the case for everyone so longer lines may be necessary).
The first time I saw an 96 SS in person was in a mall in Roanoke, VA. I remember walking around the car and the left front brake rotor caught my eye....I remember thinking those rotors are really big!
The only real trouble I had with the LS1 swap was that my caster adjustment is not quite right. I replaced some of the lower A arm parts at the same time. The tech said that he couldn't get the adjustment far enough on the right side. As such the car wants to pull that way just a little. We thought the spindle might be bent, so I put a second one on it and no change.
I need to get it to a race shop and let them look at the alignment closer. All the "general" alignment shops don't want to spend time trying to troubleshoot it.
Rookie here
