Will this tool from Jegs work?
Old Sep 8, 2016 | 11:06 PM
elis94camaro's Avatar
Default Will this tool from Jegs work?
http://www.jegs.com/i/JEGS-Performan...89711/10002/-1
I was wondering if this tool would work on removing and installing the crankshaft hub?
Old Sep 9, 2016 | 02:35 AM
cookseyb's Avatar
Good for the ballancer and hub, nothing to do with the crankshaft..
Old Sep 9, 2016 | 10:34 AM
Forgot to write hub at the end. So it should remove and install the hub with no problem then? I was looking for the Kent Moore tool but can't seem to find it.
Old Sep 9, 2016 | 10:49 AM
SS RRR's Avatar
Village Troll
That should work just fine. Kent Moore tools are hard to come by and if you do find one they are extremely pricey.
Old Sep 10, 2016 | 07:20 AM
leadfoot4's Avatar
The "trick" to removing an LT1 balancer hub, is that you need to understand it's not like an older style balancer, where the center hub area was "wide open", and a conventional puller could press against the crank. The LT1 hub has only a small hole in it's center, for the retaining bolt to pass through.
What I did, was use a piece of threaded rod, like I was going to press the hub on, BUT slid a "3 jaw" puller over the rod, locked it in with a hex nut, and threaded 3 bolts through the puller, into the hub. I then used the hex nut that I had threaded on to the rod first, to draw the pulled back, which, in turn, drew the hub off the crank.
Note the small hole in the hub, below.
