93 Firebird problem with video .
Old Oct 9, 2016 | 11:47 AM
retrofirebird's Avatar
Default 93 Firebird problem with video .
Hello everyone.
It seems like I have an issue.
Can you please watch the video and tell me what is the problem.
Thank You.
Old Oct 12, 2016 | 04:52 PM
ShovelMan's Avatar
Originally Posted by retrofirebird
Hello everyone.
Thank You.
https://youtu.be/_3AO_1P-aY8
Assuming it's a 93, check for codes.
http://www.troublecodes.net/gm/
http://shbox.com/1/Dtcs.htm
Old Oct 12, 2016 | 05:00 PM
SS RRR's Avatar
Village Troll
Initially, my thoughts are it's not good. What RPM was the engine at? Seems high.
Old Oct 12, 2016 | 06:40 PM
cookseyb's Avatar
Flat cam or lifter bleeding down allowing the valve not to close properlt
Old Oct 13, 2016 | 10:48 AM
MuhThugga's Avatar
Sounds like she's missing. Check you plugs, plug wires, and Optispark. Also check for a leaking fuel injector.
I had a 95 Impala that sounded like that after sitting for a bit. It wound up be rust that had built up on the valves. I just cracked the throttle for a bit and the engine knocked everything loose and ran fine afterwards.
Old Oct 13, 2016 | 04:04 PM
Originally Posted by ShovelMan
i ​​dont have​ any trouble code .
Old Oct 13, 2016 | 04:08 PM
Tanks for your reply.
my idle is 1500 rpm. i know its high. But i dont know how to decreise it.
Did you notice the popping sounds ?
Old Oct 13, 2016 | 04:10 PM
thanks for your reply. Where do you want to see ?
Old Oct 13, 2016 | 04:13 PM
thank for your reply.
Also she has a weak accerelation. And popping in egsaust.
Old Oct 13, 2016 | 04:38 PM
SS RRR's Avatar
Village Troll
I'd like to see/hear video taken from under the hood. Can you give a history of the car and mods and when this noise started?
