I think it's an ignition problem
Old Jan 23, 2017 | 02:57 PM
white97WS6's Avatar
Default I think it's an ignition problem
I rebuilt the motor and replaced all ignition parts 3,000 miles ago. Now when I start it, it will run for 30 seconds to a minute and shut off. Then it wont start again and I can't start it the rest of the day. Then, go out and start it the net day and it does the same thing. Please help if you can, I'm pulling my hair out trying to figure this out.
Old Jan 23, 2017 | 04:13 PM
BALLSS's Avatar
have you checked fuel pressure or scanned for any codes?
your description is brief and could be so many things....
You need to do some diagnostic checking first to narrow it down to either fuel or spark
.....a "guess" is Ignition Control Module....but just a guess from this side of the internet
best to do some diagnostic first with a code reader and fuel pressure gauge...especially when the issue occurs before blindly throwing parts at it
Old Jan 23, 2017 | 04:30 PM
white97WS6's Avatar
Ignition Control Module was replaced yesterday. I put a meter on the injectors and they are pulsing. fuel pressure is good. When I rebuilt it 3000 miles ago, I replaced the fuel pump, regulator, opti, plugs, wires, coil and now the ICM. when I rebuilt it I also installed a hot cam kit, headers and had it fully tuned from PCM for less. I dont have a scanner, but I've tried to troubleshoot everything I can think of.
Old Jan 23, 2017 | 05:37 PM
BALLSS's Avatar
what brand opti did you put in?
Old Jan 23, 2017 | 05:43 PM
white97WS6's Avatar
Accel
Old Jan 23, 2017 | 06:13 PM
Fast350Z's Avatar
Originally Posted by white97WS6
Accel
You could have a bad opti. Anything other than AC Delco/Delphi is hit or miss.
Old Jan 23, 2017 | 09:22 PM
BALLSS's Avatar
Accel
...well the chances it is a bad Opti are VERY high....
assuming your screen name indicates car year...you can get a OBD2 scanner to read codes but Opti failure does not always throw a code.
Old Jan 24, 2017 | 06:56 AM
moehorsepower's Avatar
Accel Optis do not have a great track record,
