Custom exhaust kits
Old Jan 24, 2017 | 10:23 AM
demonsmokr's Avatar
Default Custom exhaust kits
I'm feeling ballsy and want to try fabbing up my own exhaust. Buddy has a welder, and is a welder by trade, I've been ICAR certified for awhile about 10 years ago. So, i think we can do it.
my question is, what would be a good kit to start with? Jegs and summit have a few affordable kits.
Should i get one with alot of pieces? I plan on doing true duals, but just straight pipes for now. Maybe dump them at the axle or something?
i originally wanted a quiet muffler, but wife is getting impatient and wants me to fix the car before the new baby comes. So, putting off the muffler for now.
suggestions, advice, criticism welcome.
Old Jan 24, 2017 | 10:46 AM
StealthFormula's Avatar
I bought a Summit Racing x-pipe kit and had an old sponsor on here use it to fab up my true duals. I had them dump it out before with axle and use dynomax bullets for mufflers. This was probably almost 10 years ago now so I'm not sure if Summit still sells the kit or what's out there etc. but it worked out well for me.
This is what I bought and used as a reference:
http://diysrc.com/install-a-true-dua...ebird-lt1-ls1/
Old Jan 25, 2017 | 06:04 AM
Dirty_Bird's Avatar
I fabbed my own dumps with a summit x pipe, header extensions, and turndowns with magnaflow mufflers. Fairly easy to do when theres an extra set of hands.
Old Jan 25, 2017 | 04:12 PM
demonsmokr's Avatar
What size should i go? My motor is stock, but plan on doing the air intake and a decent cam this summer.
would 2.25" be sufficient? Or should i go ahead and go with 2.5"?
outlet for header collector is 2.5". Well, 3" on the header, step down flange at 2.5". I think 2.25 would be good, give me that little extra room for ground clearance, and not give me any pressure issues.
advice and suggestions? I'm about to order the pipes now to have them in by Saturday hopefully.
Old Jan 25, 2017 | 05:16 PM
Dirty_Bird's Avatar
You can do 2.5 but if you gonna mod down the road id do 3. Either way your mufflers will hang the lowest if doing dumps
Old Jan 26, 2017 | 10:08 AM
aroberson77's Avatar
What did you end up ordering?
Old Jan 26, 2017 | 12:42 PM
demonsmokr's Avatar
I got the 2.5" x pipe kit from Jegs. Summit wanted taxes. Same price though. FedEx says it'll be here tomorrow.
So, Saturday night and Sunday im putting my motor mounts in, rear main seal, installing the flywheel/clutch, transmission, trans mount, torque bushing, and fabbing up the exhaust.
I think i can get it all done. Still need my 02 extensions, but i might just make some. Haven't decided yet. Not positive if splicing the wires will jack with the readings or not.
i wanted to replace my oil pan, but after cleaning it real good, i can fix it. It got dented somehow from previous owner, and it seemed like it was leaking near one if the kinks. I went ahead and rigged it with JB Weld. We'll see how it holds.
I've found a few LT1 motors for a good price. Thinking of snagging one, or possibly doing a SBC to build up.
Anyways, i plan on documenting it best i can for future reference. I feel theres not enough info out there for the LT1, so gonna do my part to help out.
Old Jan 26, 2017 | 02:05 PM
2.5" should be good for a stockish motor, good luck with everything. I would probably do a TPI SBC build with vortec heads if I were you and leave the potential opti problems behind.
Old Jan 26, 2017 | 03:15 PM
demonsmokr's Avatar
That's where I'm leaning. I did a new opti, plus and wires when i got the car. Total pain in the ***.
i just want to limit the amount of cutting. Would those crab style distributors give enough clearance so you wouldn't need to chop up the cowl area?
i always wanted to build up a motor using the Holley stealth ram intake. Ever since it came out, it haunts my wet car dreams.
Old Jan 26, 2017 | 03:20 PM
I am not sure, I don't have a Camaro, but I would think that you could make it fit with minimal modification.
Old Jan 28, 2017 | 07:18 AM
leadfoot4's Avatar
I'll assure you that with the OE, LT-1 intake, you probably wouldn't be able to get an "conventional" distributor in there, as the fuel pressure regulator and EGR valve are right where the distributor would normally live. Secondly, it's questionable if you could get a distributor in or out of the engine, if you had to, while the engine is in the car. I don't think there's enough room above the engine, to be able to lift a distributor, even with the cap off, with the cowl uncut.
Old Jan 28, 2017 | 08:21 AM
I wouldn't let an opti spark prevent you from putting another LT1 motor in the car. I've owned a couple LT1 cars in the past 13 years and I've never had an optispark related issue. People make it out to be way worse than it really is. Plus, a couple things can be done to the opti to help prevent potential issues so it's really of no concern when using a quality OEM unit IMO.
Old Jan 29, 2017 | 09:18 AM
demonsmokr's Avatar
Its not just the opti unit. I guess when i build it, i can eliminate, or prevent alot of the known issues.
Plus, the guys at work keep talking **** about my LT1. Makes me want to keep it even more. But need atleast 400hp and different gearing to keep up with their newer rustains and fat cam-a-rows.
So, I'm gonna stick with the LTx. Hopefully will finish everything up today. About to go stab the transmission in, and start figuring out the exhaust.
Need a damn starter. Didn't realize when i took it out, it's cracked. Solenoid split from the motor/spindle. Not sure how, but it never struggled starting. All the local shops gotta order it. Dammit.
But yeah, I'm gonna stick with the LTx. But that'll be later on this summer when i start building it up.
Old Jan 31, 2017 | 07:44 AM
smitty2919's Avatar
Plan it out, buy appropriate bends and get to cutting/welding. Here is my build:
https://ls1tech.com/forums/lt1-lt4-m...e-exhaust.html
I'll never buy/build another system that has the "typical" Y merge again.
Old Jan 31, 2017 | 10:47 AM
hrcslam's Avatar
I did my own O2 extensions. I used the trailer wiring. It comes with 4 wires bonded together and are all different colors. Cut and splice. I haven't had any issues in 3 years or 40k miles with it.
While not absolutely necessary, you'll want to have the tune adjusted for the additional VE of the headers and you'll also want to have the O2 tables adjusted for delay too (it takes longer for the exhaust to get to the O2s on long tubes vs stock manifolds).
