HP estimate
Old Feb 15, 2017 | 02:13 PM
Flycaster1977's Avatar
Default HP estimate
i searched a good bit and i kind of have a round a bout hp number in my head, but i would like other opinions before i put it all together. Thanks
93 lt1--60k miles on factory short block, arp rod bolts and new bearings. Trick flow 195's that are milled to 55 cc combustion chamber and ported, intake port matched to heads, 52 mm tb, ls7 lifters, crane 1.6 rockers, lt4 hot cam, patriot headers, high flo cat, and gmmg exhaust.
Old Feb 15, 2017 | 02:23 PM
soloman369's Avatar
350hp
Old Feb 15, 2017 | 02:25 PM
KW Baraka's Avatar
Originally Posted by Flycaster1977
HP estimate
With a hot cam?
Not more than 325 to the wheels.
KW
Old Feb 15, 2017 | 02:51 PM
tbird31's Avatar
Originally Posted by KW Baraka
With a hot cam?
KW
I agree with solo. He will be in the 350 range. Buddy of mine had a bolt on and hotcammed LT1 made 345wheel. He's got heads too, however conservatively I'm thinking 350-360.
Old Feb 15, 2017 | 03:11 PM
aroberson77's Avatar
those heads can run a way bigger cam, you're shortchanging yourself
Old Feb 15, 2017 | 04:17 PM
BALLSS's Avatar
since we are bench racing here....350 rwhp may be a bit high with the hot cam but not far under that
unless OP has the hot cam now...I would get a custom grind from LE.
I had a stock bottom end, mildly ported GM AL heads with the same bolt ons (but shorty headers) and made 350 RWHP & 351 RWTQ. This was with a baby 214/220 custom cam on a 91 octane tune
Old Feb 15, 2017 | 05:33 PM
I do not have the hot cam as of yet. I have everything else i posted above. I am not entirely decided on the cam. I know there are better choices for more power, but im also looking at reliability and driveability.
This car is an a4 and im going with either 3.42 or 3.73 gears.
Old Feb 15, 2017 | 05:53 PM
nickp's Avatar
Definitely choose a different cam. Those heads have much more potential
Old Feb 15, 2017 | 06:36 PM
Dirty_Bird's Avatar
Id do a custom grind cam
Old Feb 15, 2017 | 08:41 PM
Nick.H's Avatar
custom cam ftw contact Lloyd Elliot, or the CC503 is a popular off the shelf choice
Old Feb 15, 2017 | 08:54 PM
350 groundpounder's Avatar
360rwhp
Old Feb 15, 2017 | 09:57 PM
BALLSS's Avatar
The Hot Cam will be "OK"....but given the cost and effort to do a cam I would go with newer cam technology and a custom grind from Lloyd
http://elliottsportworks.com/?page_id=32
You should be at the 350hp goal with his 218/224 one but the 224/230 one would make more power and have a little more "cam idle" sound.
Your stock injectors and fuel pump may not be enough so factor that into your cam choice. 30 lb injectors and a 255 LPH pump. PCM tune regardless of what cam you pick
Old Feb 16, 2017 | 06:47 AM
I was looking into his 224/230 cam but had also considered the 226/232. I also just contacted Ai to see what they have to offer. This engine is going into a third gen iroc that is carbed. I had already figured in the fuel pump, but not the injectors. Thanks for the heads up.
Old Feb 16, 2017 | 07:08 AM
I got a CC503 and am probably getting some 30lb injectors as well. are your rockers self aligning?
Old Feb 16, 2017 | 07:15 AM
they are self aligning
Old Feb 16, 2017 | 03:58 PM
KW Baraka's Avatar
......This engine is going into a third gen iroc that is carbed. I had already figured in the fuel pump, but not the injectors........
Carb'ed LT1 won't need injectors.
KW
Old Feb 16, 2017 | 05:56 PM
BALLSS's Avatar
??? carb LT1 going into 3 rd gen, cool,...so you won't be needing injectors. And yeah if carb than a new fuel pump (like about 4-5 psi for the carb). I will put a carb LT1 into my 70 Nova
My $.02 on the SA RR....if your going with a cam that wants to rev to 6700 let alone 6100 I would go with NSA RR and guide plates. High RPM's and SA can not mix well and the SA RR can pop of valve tip. 5700 RPM is about it for SA, IMHO
and if this is a carb motor with Trick Flow heads you might want to discuss with Lloyd on a cam for the carb motor vs selecting from the various ones for LT1 FI cars he lists on his site.
Old Feb 16, 2017 | 06:34 PM
KW
no the original is carb'd but the lt1 will be efi.
