MAF cleaning.
Old Mar 19, 2017 | 11:50 AM
aaahicks1's Avatar
Default MAF cleaning.
I have a descreened stock MAF. My car is running really crappy. Is it ok to clean the middle part of the MAF? Can I get the middle part wet without messing something up?
Old Mar 19, 2017 | 12:18 PM
StealthFormula's Avatar
Buy some CRC MAF cleaner and give it a good cleaning. Be careful not to touch any of the sensors with the spray tip. If you still have the MAF screen, clean it and put it back on. If not, buy one and put it on. Descreening the MAF is often a bad idea that causes issues like you describe.
Old Mar 19, 2017 | 12:39 PM
myltwon's Avatar
Electrical parts or MAF cleaner only. Don't make any contact with the wires it's extremely delicate.
Old Mar 19, 2017 | 01:09 PM
aaahicks1's Avatar
​​​​​​​can I put cleaner on the sensors and clean them at all?
Old Mar 19, 2017 | 01:37 PM
aaahicks1's Avatar
Ok I just reread Myltwon comment. No contact with electrical parts.
Old Mar 19, 2017 | 02:11 PM
Yup, just spray it on, don't touch anything and the cleaner will work it's magic. It will evaporate so no need to wipe anything down. The CRC stuff is good ****. Good luck and be sure to report back.
Old Mar 19, 2017 | 03:07 PM
aaahicks1's Avatar
Thanks guys, I really appreciate the info.
Old Mar 19, 2017 | 03:13 PM
2ToeRacing's Avatar
I never heard of that de-screening a MAF is bad. My s-10 doesn't have a screen and it runs great.
Old Mar 19, 2017 | 03:39 PM
My Z06 has a screenless MAF from the factory but it just seems best to leave a factory MAF alone. Over the years there have been several posts where LT1 individuals have descreened their MAFs and experienced issues. It's quite possible that some of them accidentally damaged the sensors while prying them out, who knows. In the LSx world many people have used ported MAF ends and had issues as well. Many people have been okay altering their MAFs but a MAF that's been altered in any way is always a potential culprit when a vehicle isn't running correctly.
Old Mar 19, 2017 | 03:52 PM
BALLSS's Avatar
the screen is there to "stabilize" the incoming air so the MAF has more stable air flow through it
if you have a oiled air filter (K&N) and use to much oil on it, that gets on the MAF and it doesn't read right. Cleaning with the electrical or MAF cleaner will clean it right up.
Old Mar 20, 2017 | 04:33 AM
AdsoYo's Avatar
Is the screen sold by itself anywhere?
Old Mar 20, 2017 | 06:47 AM
Come to think of it probably not since they weren't intended to be separated. I guess the only way would be to buy another unit.
Old Mar 20, 2017 | 06:49 AM
myltwon's Avatar
I'd just snag one from a junkyard. If you take just the screen they probably will charge little to nothing for it over the whole MAF.
