Fuel pump not working
I have swapped the relay under the driver side kick panel and ran 12 volts to fuel pump prime connector next to PCM and the fuel pump still didn't turn on. I also checked the wiring running from the pump assembly and everything looked look. So what else could there be preventing the fuel pump from turning on. Only thing left that I can think of is the Viper alarm system on the car. The engine cranks so I didn't think the alarm system could be an issue.
Hope others can chime in as well!
I reinstalled the fuel pump and went to start the car and nothing, fuel pump is not priming. At this point I am ready to push the car off a cliff as this is the 3rd or 4th time I have taken the fuel pump out of the tank. Doesn't make sense, the main wires that go to the top of the fuel pump assembly must be bad even though there was no sign of damage on any wires. Hopefully after I swap the entire fuel pump assembly the fuel pump will work.
