daily LT1 build
Old May 2, 2017 | 07:15 PM
franjul08's Avatar
Default daily LT1 build
hi first my english its not that good so please sorry if you see some mistakes in my writting
got a 94 Trans am for 3 years now, auto 4l60 2.73 rear axle, never dynoed it
im loocking for some extra power without boosting it
engine internals are completely stock, long tube headers, y pipe, flowmaster muffler, cat delete (no regulations in my country), egr delete, msd coil and module, 58mm tb
stock ecu, stock opti
what kind of cam and other internals do you guys recommend for a 300-400whp daily build
thanks
Old May 2, 2017 | 08:18 PM
96lt1m6's Avatar
58mm on a stock automatic
CAI like K&N or if you have a ws6 hood in mind do the Ls1 lid set up it works very well
You need some gear in that car, 3.73s come to mind however, if you find a 3.42 rear from a 6spd car that will work
New valve springs, 1.6 rockers
Underdrive crank pulley
3200-3600 stall with the largest capacity tranny cooler you can find to fit
160° thermostat
And most of all have that pcm tuned....
I personally like the cc503 cam and heads done by someone reputable cough cough LE2s or AI you will not be let down by either..
Old May 2, 2017 | 09:52 PM
franjul08's Avatar
160° thermostat
i have the ws6 hood so that ls1 setup would be great, what do you think about a 3.23 gear?
LE2, AI? can you please send me a link?
that 58mm was a gift from my ex-gf father he owned 3 lt1/lt4 c4's
thanks for the reply
Old May 3, 2017 | 02:06 AM
LT1383Z's Avatar
Stall & gears next
http://elliottsportworks.com/
http://advancedinduction.com/
3.23 is okay but I would run a 3.73 like 96lt1m6 had in mind
cc503 is a great cam but if you decide to go with AI or LE (advanced induction/Lloyd Elliot portworks) I would discuss your goals with them and have them do a custom grind
You'll want to have the intake done when you do the heads if you haven't already 58mm TB on stock intake is not good
Old May 3, 2017 | 03:04 AM
96lt1m6's Avatar
3.23 gears and an Lt1 are not a very powerful combo. Ls1 can do magic with 3.23s..... Lt1s need a little more gear to put us in that sweet spot.
http://www.advancedinduction.com/LTX...inderHeads.php
Old May 3, 2017 | 07:39 AM
franjul08's Avatar
Originally Posted by LT1383Z
Stall & gears next
3.23 is okay but I would run a 3.73 like franjul08 had in mind
Thanks for the reply
What benefits would give me a 3200-3600 stall? (dont know much about them)
The problem with that is that i live outside the us so i need to order my cam and others and have them installed here
Got my intake done to go along with the tb
Thanks
Old May 3, 2017 | 07:40 AM
franjul08's Avatar
Main differences between 2.73 (my current gear) and a 3.73? What differences should i see/feel
Old May 3, 2017 | 08:19 AM
96lt1m6's Avatar
Acceleration, gets the car moving and keeps the motor in a usable powerband. I have done the swap from 2.73 to 3.23 to 3.42 to 3.73 and 4.10.... the first 2 don't have a considerable amount of difference from my observation. For an automatic 3.42 and 3.73 are great but the 3.73 gear is what i would consider optimum.
Old May 3, 2017 | 09:56 AM
franjul08's Avatar
Is it true that a 3.73 gear will get the car faster and make more agressive burnouts but the top speed will be less?
The transmisión will still change trough gears normally?
Old May 4, 2017 | 01:10 AM
96lt1m6's Avatar
Yes, you will lose some top end so no freeway racing or get a 6 speed
Old May 4, 2017 | 10:18 AM
SS RRR's Avatar
Village Troll
AI and LE are not the only players in the game. You can talk to Craig from GTP as well:
http://www.gtp-racing.com/
Old May 4, 2017 | 03:47 PM
Christianweber's Avatar
CAI, 3.73's, a 3000+ stall, and a tune will make a huge difference. Nitrous is also a cheap way to add 100-150 horsepower on demand. The stock LT1 can handle a 150 shot of nitrous all day as long as it's set up right.
Old May 4, 2017 | 03:56 PM
ShovelMan's Avatar
the address on their web page doesn't exist anymore. Drove by there and it's abandoned.
Old May 4, 2017 | 05:12 PM
SS RRR's Avatar
Village Troll
Their FB page shows a different address:
4116 Siegel St
Houston, Texas, TX 77009
Going to call tomorrow.
Old May 4, 2017 | 06:27 PM
ShovelMan's Avatar
4116 Siegel St
thats more like it! Looks like a house and a warehouse of some sort in the rear.
Old May 4, 2017 | 06:38 PM
franjul08's Avatar
can you please explain to me what the benefits would be from a 3000+ stall converter
dont know much about it
thanks
Old May 4, 2017 | 08:43 PM
myltwon's Avatar
thanks
in simplest terms a stall converter will act like having a manual with the ability to select the rpm your car will launch at based on the advertised flash rpm.
instead of your current converter which is around 1600-1800rpm the car will leave at a higher rpm more into the power band of your engine. They do generate more heat so you will want to upgrade to larger external transmission cooler.
Old May 4, 2017 | 10:41 PM
franjul08's Avatar
thansk a lot for the explanation
so with the mods that i already have + bbk underdrive pulley, CAI, 3000+ stall and tune.. how much whp do you think the car would have? just to have an idea
thanks
Old May 5, 2017 | 02:02 AM
LT1383Z's Avatar
thanks
I would guess somewhere in the 260-290 range depending on how well the car runs.
Stall & gears don't add horsepower in fact I believe they reduce it if purely looking at dyno numbers but they wake the car up quite a bit.
And since you want to know more about stall converters this write up should help you understand a bit better http://www.badasscars.com/index.cfm/...d=78/prd78.htm
Old May 5, 2017 | 10:12 AM
SS RRR's Avatar
Village Troll
eh, called and left a message. we'll see if my call is returned.
