Temp Guage?
Old Aug 13, 2017 | 07:33 PM
elis94camaro's Avatar
Default Temp Guage?
Does the temp reading on my temp gauge look normal after a 17 mile round trip with 92 degree weather? Pic is below.
Old Aug 14, 2017 | 09:39 AM
NewOrleansLT1's Avatar
Ya that's about normal with the stock thermostat and fan settings..
Old Aug 14, 2017 | 10:21 AM
I forgot to mention that I have it tuned for them to come on at 195 and 205 and I do have a stock thermostat. Is that still considered acceptable?
Old Aug 14, 2017 | 11:17 AM
SS RRR's Avatar
Village Troll
Seems normal for stock t-stat. Is that driving on the freeway or stop/go? Is your coolant sensor working or is the light on the dash a false alarm?
Old Aug 14, 2017 | 11:31 AM
This was driving on the highway mostly mixed with some stop and go. I checked the radiator before this trip and it was full so I'm guessing it might not work. This also was the first real drive since the motor has been rebuilt.
Old Aug 14, 2017 | 12:00 PM
BALLSS's Avatar
Originally Posted by elis94camaro
I forgot to mention that I have it tuned for them to come on at 195 and 205 and I do have a stock thermostat.?
if the tune is to turn on fan temps lower...might want to install a 160 stat. From the gauge pic my "guess" is the needle is indicating something like 2xx temp...which would coincide with the 205 fan on temp
the "new" rebuild motor is "tight" (rings) and could run slightly hotter initially
Old Aug 14, 2017 | 12:56 PM
So this shouldn't be a concern then. I was trying to get everything sorted out before I started to daily drive it.
Old Aug 14, 2017 | 01:17 PM
BALLSS's Avatar
your dash gauge may not be precise....drive it and keep an eye on the temp gauge. If it gets hotter you should look into your cooling system deeper...(read bleed it again)
