High compression and 250 shot bad idea?
Jus' sayin'.....
Oh......I don't spray nitrous, BTW.
KW
How do you know you are not getting any detonation? Are you running knock sensors with a solid roller cam? Do you go WOT on pump gas or run a different tune for pump gas? Just curious as I do not have it in me to risk popping a piston.
Knock sensors? We don't need no stinkin' knock sensors!
Oh, OK.....I see you got jokes.......
But if you were really a smart guy, you'd know I have no longer have a need for such things.
Now run on back to the sand box with the kiddies and leave this discussion to the big boys.
KW
KW
8.8-1 dynamic is still pretty high but doable for pump gas with a good tune. I would think you would not be able to hear any detonation at WOT unless you are running stock style mufflers. I would be curious if you find any signs of detonation if/when you pull the engine apart for refresh/mods.
BTW, watch your summer/winter gas fluctuations. I have talked to refinery engineers about fuel differences and was told the summer gas is better for performance cars as it has a higher vapor pressure and is a little more resistant to detonation. They start to transition in Sept to the winter gas.
KW
