New Engine Dyno Results!
Finally got it started. It starts out ideling around 1500rpms and drops down to about 1k rpms. Any ideas why? Here's a clip of it running at 1k RPMs.
https://youtu.be/vVa60Li4xRA
I've had the car since I was 16 so just over 10 years now. This is a new motor that u had built and installed myself with a couple friends. When I say it idels at 1500 rpms it idels like that for 5 minutes and drops down to about 1k RPMs. I know the computer is learning still but wasn't sure if that was normal or I'd that is adjusted in the tune. My Dyno/tune day is November 14th. They put a base tune on the computer so I could get it running. Finish line performance will be the ones tuning it.
A baseline tune to get the car running is just that.
You want that very modified engine to run right.....you get it tuned.
Your idling issues are normal for a performance engine that does not have a performance tune. Hell.....I'd bet it's running rich, too.
BTW.......a street tune is better than a dyno tune if drivability is a concern. Make sure FLP does both.
Jus' sayin'........
KW
Jus' sayin'........
KW
Jus' sayin'........
KW
Jus' sayin'........
KW
Okay thanks guys sorry for the silly questions just new to owing a car with a cam besides stock. How long would you say it should idel at 1500? It ideled like that for probably 10 minutes. This is the first couple times it has been started so I wasn't sure if the computer is learning. Dyno day is November 14th.
Yes.....it should always be an option.....but with some shops, you do have to ask for it.
Remember.....tuning on the dyno is almost ALWAYS at WOT.
Tuning on the street is under 'normal' driving conditions, normal acceleration/deceleration, normal part-throttle shift points and TC lock-up.
KW
KW
Its based on engine temps not time.
