Diff 26019044
just got a donnor rear end, found a diff inside with the numbers 26019044. Looking into the parts manual i dont see that numver on anything. Second in between the small gears there is like a ig clip with some springs but looks like one is missing. How many springs go in there, what is the part number because it also doesnot apoear in the manual.
Thanx
The 3.23 gearset indicates it was from an automatic transmissioned car.
The carrier is a 3 series,28 spline.
You might not be able to pull the plates out with the ring gear still on the carrier(gear teeth might be in the way).
In case you do have to remove the ring gear,the 10 bolts holding the ring gear on ARE LEFT HAND THREAD.
. Where can i get those spring i think there are some missing, how much should there be??
