Looking for detailed step-by-step on head swaps
If you want to find out the sweep, take a rocker off, mark the valve tip with a Sharpie, readjust rocker, start engine for a few seconds, turn engine off, take rocker off and see how the roller is contacting the valve tip.
So far the worst part has been getting that passenger side header on. The bolt holes didn't quite line up and it took me an obscenely long time to finally get it using a breaker bar to bend the front primary. I also stripped the bolt hole right under the alternator (of course it would happen to that one in particular) and had to use my thread chaser to fix it. The bolt is still slightly off but it seems tight so I'm keeping my fingers crossed.
The intake is now threatening to take the cake since those bolts don't line up either! The intake bolt holes are just barely wider side to side than the heads. On the stock heads they lined up perfectly. I did a search to see if anyone else had this issue and found a thread from 2006. I'm surprise Trick Flow hasn't corrected it after 12 years. My plan is to use my dremel to grind away at the intake holes and make them larger unless someone else has a better idea...
As far as the bolt holes go, for future reference, holes that don't go into water jackets, just use a trace of oil on the threads. Make sure only a trace or risk hydrolocking the bolt and not getting an accurate torque reading.
Thanks guys, I spent about an hour and a half grinding and finally got it to the point that all bolts will thread. Hoping to start this thing tomorrow!
On that note, due to the debris that fell into pretty much everywhere, my plan is to fill it with fresh oil and distilled water, let it warm up to full temp, then turn off and change fluids. Then run it for 1 tank of gas and change fluids again. Overkill?
What I'm asking regarding the intake, is it bottoming out on the front and rear china walls? if so you need to have the intake milled as well.
Here's how the intake lines up:
In wet mode it will pretty much suck all the water out of the motor through the thermostat port. I run it a lot while scraping the block, intake...
The oil system of an engine is like a blood stream. It must be kept surgically clean. If even a single tiny bit of crust or metal gets in there it will embed or block an oil passage and the motor will be trash. This is why I never touch engines that have been open and why a majority of generic engine work such as cam swaps turns motors to trash in 10k miles.
I spent hours powerwashing and cleaning all of my engine internals and the engine block, blowing out all the oil passages, assembled everything while paying the closest attention to the details. I got around to installing the cam and noticed that Karl installed the cam bearings wrong. Pulled it all back out, sent the block to the machine shop and had new cam bearings installed. Got the block back and washed everything again before installing.
It only takes one bit of crap to destroy thousands of dollars in work. Don't cheap out. It's only time, effort, and a $5 tube of black RTV
Edit: what kind of rockers and springs are installed? The stock covers are not compatible with most aftermarket rockers. You can remove that shield, but your PCV system will be sucking down a crapload of oil mist and depositing it into your intake. If you elect to go this route, a catch-can is almost a must.
