Looking for detailed step-by-step on head swaps
That's weird. I've always wiped surfaces clean with brake clean and have never noticed surface rust form.
Seran wrap, plastic wrap, rain coats, theres all kinds of protective things you can throw over, no excuse to let it open
Even with brake cleaner, you're still leaving behind a layer of 'stuff' from the ether based solvent evaporating.
https://www.summitracing.com/parts/nal-10108689
That was close, thanks man.
I have two new A/C seals because I'm replacing the compressor during all this too. The outer diameter is the same but the inner diameter is larger. I just went ahead and ordered 4 from summit.
Also did some more reading and watched a Youtube video on head swaps. Now I'm second guessing whether I coated the head bolts correctly, specifically the top 4 bolts on each head. I didn't use sealant on those, only grease. When I cleaned the bolt holes, I noticed the top 4 on each side didn't enter coolant passages, they were just shallow bolt holes that didn't bore through to anything. Now I'm wondering if I checked each one thoroughly enough to make sure that they were all the same. Since the heads are now installed, can I remove and replace each of those 8 top bolts one at a time and be ok? Or would I have to remove all head bolts and install them in sequence again? When I cleaned the holes I used one of those gun barrel brushes and I'm 90% sure I bottomed out the brush in each bolt hole to ensure it didn't enter a passage.
we have customers who return unused items for retest when theyve been sitting in their warehouse for eons. there will be rust on the the lot of it but whatevers been sprayed with 400 looks brand new since the day we machined it.
I could've sworn those tapped into the water jackets. If it were me in that situation I would do that one bolt thing, but would then run through all bolts using the proper bolt numbered sequence at whatever highest torque value you used, but again, that's just what I would do.
Also, I checked my pushrod length with this "pushrod length checker" tool and wanted to double check with all of you that I'm safe keeping my current set. I read about how people usually use the method where you install a light spring, use marker on the valve and crank the engine by hand but I want to see if I can get away with this other method. The tool is resting on both the valve and pushrod, no spaces at all. Right now both 4 and 7 are TDC and they both had the same result.
