Whipple LT1 Idea
So first off, I know people have thought about making a positive displacement style supercharger work on the LT1 and a few have even made them with custom made/machined intakes, or remote mounted the blower.
My idea is would be to use a SBC Whipple intake with intercooler, and modifying it to work on the LT1/4, which I would think would be the same as converting a SBC intake to the LT1? Then to use the rear pulley setup with throttle body on the front of the supercharger. Obviously this would require a non-stock hood, but I have a taller than stock hood already and don't mind trimming the cowl. I would assume that this would be the easiest/cheapest way to do a Whipple LT1. Thoughts, input, info from those who have attempted this? This isn't a near term goal for the car, but it is a long-term (2-3 years) goal and I think should be doable?
http://www.corneltechweb.com/superchargerweb.htm
Link to Whipple SBC kit that is NOT carb setup?
Not many people have completed one so to say you have a roots blower on a LT1 is nice. But once you talk about efficiency/power potential/packaging/cost compared to turbo, it's hard to stick with the roots setup.
For my needs for autocross and road racing, a roots will give off some heat unless properly intercooled. Which brings you to a packaging issue. Next, almost everything will be custom machined/welded. A turbo would suit me better as there is only piping fabrication and some brackets to fab up but I would be looking at a rear mount as to keep some weight off the nose of an already nose heavy LT1 car.
Adding a turbo housing (weight) under the trunk on passenger side would be beneficial from a corner balancing aspect. Same idea relocating battery to that area.
Not sure what you mean by boost creep, but I suppose if you do not have total control of the system it would creep at WOT on you.
You could always overwork a larger blower and use a gate on the cold side with a boost controller to always have solid boost at lower RPM.
That being said, a TVS would be pretty friggen sweet to see under the hood.
Intercooler will raise it about 1" but the jack screw will need to be above whatever injectors'fuel rail you will run. Which will raise it even more.
