Fuel Tank Leak
Long story short, I put my car in storage in October of 2000, pulled it out in 2006 or 2007 and started working on getting it running, at which point it needed new "everything", including a fuel tank.
This past weekend I finally got it out to drive after 17 years of "sitting". The first thing I did was take it to a gas station to "fill it up". The brand new Spectra fuel tank we put on it a few years ago appears to be leaking and as best we can tell it's where the filler neck enters the tank. This was the first time the tank had been filled up, but we have been putting gas in it over the last several years, five gallons at a time via gas can, without issues.
I've attached a couple pics that show the nature of the leak. The gas was running down the driver's side of the tank, dripping onto the exhaust shielding and exiting on the passenger side of the car. I have to admit that was the most awesome part of the "first drive". I almost wanted to drop a match, but that would have probably blown up the entire gas station, along with myself and several innocent bystanders.
The leak eventually stopped when the fuel level reached a certain point and I was able to drive the car, which was a lot of fun after having not driven it in such a long time. It seems to run & drive better than ever with the addition of Kooks headers, GMMG exhaust, Strano springs & Koni shocks.
Has anyone effectively fixed a leak like this with epoxy/JB Weld or other means? I would really like to avoid pulling and replacing/repairing the tank as it can be, or is, a huge PITA.
Permatex makes some good stuff, so this might work.
https://www.permatex.com/products/sp...nk-repair-kit/
I know it's a pain, but I think I'd pull it and get it welded.
They seem to make a couple products that might work in this situation.
https://www.jbweld.com/collections/w...xy-putty-stick
https://www.jbweld.com/products/j-b-weld-tankweld
The Spectra tank I put on has a three year warranty, but I'm pretty much certain it's been on the car longer than that.
Pulling the tank is such a huge PITA. It might be easier if you drop the rear end and have a lift.
I'm probably going to try some sort of on car repair via epoxy etc. If the hole was anywhere else, I might be a bit more reluctant to try that solution. If it fails, I guess I'll pursue other options.
I know every car is different, but I don't remember pulling the tank on my 93 being too difficult. Jacked it up high with stands on the body, let the rear end hang until it bottomed out, then tank shimmied out after releasing both straps. This is also with the older fixed style filler neck - I think they eventually went to a flexible one?
I think I'm going to try the epoxy route. Removing & replacing/repairing the tank will be a last resort.
Short of replacing or welding/soldering the tank, I was curious whether anyone had successfully addressed similar, or any, leaks via other means.
It is not under pressure or anything assuming your vent system is working, and only touches gas when completely filled to the brim so you will be fine.
https://www.jbweld.com/products/kwikweld-twin-tube
I actually asked this person about using Steelstik or Tankweld. They said they could be used, but in this particular situation they felt that their original product would provide the best results.
Might want to hit the area with a wire brush then wipe clean with acetone before applying. Let it fully cure/dry before driving the car
With the tank still mounted, I honestly don't know what type of access I'll have to the area where the epoxy will need to be applied. I just know that removing the factory tank and installing this new tank was a pain, and that seemed to be primarily due to the fixed filler neck.
