Which Y pipe
Old Dec 13, 2017 | 10:21 AM
biketopia's Avatar
Default Which Y pipe
Got my gen1 swap done in my 95z and have a set of hooker lt's in it. Looking to see what y pipe any of ya'll have used. Obviously the hooker should hook up, but's it's $100 more than some of the other options. Any suggestions on a y and exhaust set up would be appreciated. Thanks.
Old Dec 13, 2017 | 12:44 PM
smitty2919's Avatar
Make your own with a Flowmaster merge. A lot of options out there are junk design.
Old Dec 13, 2017 | 01:32 PM
biketopia's Avatar
Alright, after I posted this up I did some more digging and had remembered reading about the flowmaster merge. Just get a couple different bends and go from there? What about the rest of the exhaust, just do the same?
Old Dec 13, 2017 | 02:03 PM
smitty2919's Avatar
Buy any catback you want, build a y pipe from headers to the catback. That way if you want to change the catback, you can and the y pipe will still work.
Old Dec 14, 2017 | 06:49 AM
biketopia's Avatar
Wordage, thanks. I'll do that!
Old Dec 14, 2017 | 10:48 AM
SS RRR's Avatar
Village Troll
From what I understand is this merge also eliminates the rasp we all suffer from with the traditional merge.
Old Dec 14, 2017 | 12:08 PM
smitty2919's Avatar
It does. My PS Y pipe was horrendous. All the aftermarket merge pipes are made pretty similar.
I made my own setup and is very smooth.
https://ls1tech.com/forums/generatio...ust-build.html
Old Dec 14, 2017 | 02:37 PM
BTC's Avatar
BTC
From: Lansing, MI via Bowling Green, KY, Dalton GA, Nashville, TN & Atlanta, GA
The merge on Kooks y-pipes is much nicer than it used to be.
Old Dec 14, 2017 | 04:03 PM
biketopia's Avatar
The kooks is quite pricey, and if the flowmaster takes care of the raspy I'll get some pipe or canabilze a kit from somewhere and make my own one weekend.
Old Dec 14, 2017 | 04:21 PM
BTC's Avatar
BTC
Yeah, I was just making a general statement as their new merge is now similar to the Flowmaster merge.
The Kooks y-pipe probably wouldn't work anyway, at least not without some modification, because I think Hooker headers use a ball & socket type flange on the collector. I could be mistaken.
Old Dec 14, 2017 | 06:44 PM
biketopia's Avatar
The newer ones may, but mine are the typical 3 bolt flange ones.
