Looking to quiet down my exhaust...
Village Troll
Right now the car has an ORY into SLP 2OTL with a cutout that only gets taken off if I go to the track. I would like to keep the ORY and cutout so I'm wondering if anyone has had any experience with bullet mufflers of any kind?
Restrictive? How do they sound?
I've had good success with classic chambered exhaust - powerstick. Have a 25" on one car and 31" on another. All 3" in the center, 3.5" total round. Model 3026SB and 3030SB. Sound is unique with the LT1, that's for sure. Both cars have no cats. The shorter 25" one I have on a H/C car, the 31" is on a stock auto with just headers.
Village Troll
Thanks for the replies. Now that I think about it, I have very limited space on the Y-pipe because it's pretty close to the drive shaft. Not sure even a bullet will work.
SLP 2OTL is the stock muffler. It is manageable at idle and cruising speeds, but because of the way it's geared it gets up in the RPM band pretty quickly. Besides that I'm old, the original owner and the car had an ORY thrown on two years after it was bought new.
I love the sound of a magnaflow 18” bullet, but it’s loud. My plan is to extend the 18” bullet all the way out the back, see if that helps, or leave the bullet in the I pipe of another cat back to make it really quiet. The tone is awesome right now, but it wakes the neighborhood.
Moderator
Brian,
I've been down this road with many cars and have had the most success with the SLP dual/dual. It flows extremely well and is quiet. In fact, the only catback exhausts I use on my cars is either the 2OTL (my favorite) or the dual/dual (better sound control).
Maybe try that first. If you don't like it, remove and sell it for what you paid for it. I've also experimented with welding a bullet muffler in the intermediate pipe and that has helped; however, I'd still try the dual/dual first.
Village Troll
Eh, I like the 2OTL look too much to change out the muffler. I think I'm just going to have to deal.
Moderator
I don't disagree one bit on the 2OTL. By far my favorite as well.
Either cats or a bullet in the I-pipe. That's about your only options at this point. Cats will quiet it down noticeably and are quite low-profile these days. All my cars are lowered as well and I've survived with them. The right cats won't net you much power loss either. My 620rwhp NA Z06 only suffered a 6rwhp loss by adding cats.
A 3" bullet in the I-pipe is the cheapest option; however, you'll need to "massage" the floorboard to allow for retaining ground clearance on a lowered car. I once had a 4" bullet (5" O.D.) in the I-pipe of my car (lowered with Hooker LT's) and it survived. But, I did scrape it a few times
I almost bought a new 2OTL off ebay when I was working on my exhaust, but ended up going with a GMMG. It's too bad they don't make those exhausts anymore. Those were my two favorite catbacks based upon numerous sound clips.
Village Troll
So you're saying to look into cats for a Z06? Are they higher flowing than those off a regular Vette? What diameter are they?
Thanks buddy.
... and there's good room between the header and merge for catalytic converters. That may not only cure the loud issue, but also the "smells" issue as well!
Thanks buddy.
Thanks buddy.
Moderator
Thanks buddy.
Thanks buddy.
The cats I have on my Z06 are the ones that come with the American Racing headers. I'm not sure of the manufacturer, but I'll search around. As tbird31 mentioned, you can use any universal (quality) cat such as Magnaflow. They are very low-profile these days.
A cat on each side of the Y-pipe will quiet down the car noticeably. It certainly won't make it sound like a Honda (which none of us want!), but it will take the edge off significantly.
Plus, you won't smell
Village Troll
Thanks again for the replies. That'd be great if you could get the name of them, Jason.
I'm using a chassis mount torque arm, where the y-pipe goes through a cross brace so it hugs the underside pretty tight. I'll have to crawl under the car and see if it's possible.
In for the results.. I’m on the same quest for quetiness..
I'll also agree that a cat won't make any noticable difference to your power output. I haven't done any dyno runs without the cat, but in discussions with my tuner he said you're only talking 2-3 whp difference in general. I put down 360 whp with a single high flow cat after the Y, and I have no worries that it's restrictive at all.
It doesn't need to be a special one, just any decent quality high flow.
