Catch Can - LT1 with Boost
Thanks!
My intake must be from a 93 as it has the PCV valve and then goes a 180 basically and routes right back into the intake as seen in this picture! Did he sell you the valve cover breather?
Run passenger side valve cover tube to inlet of can
Block off TB with cap
Run vacuum barb that is currently hooked up beside PCV valve to exit of catch can
Run PCV hose to supercharger intake
To me this doesn’t sound right as the PCV will end up dumping into the SC inlet? I almost assuming the PCV exits from motor and doesn’t enter there?
I made a shitty small drawing
