LT1 problems lol
Old Jan 27, 2018 | 01:38 PM
Kat Crescent's Avatar
Default LT1 problems lol
Hey people. having a issue.
so my check engine light came on. took it to the dealer and they said its my airflow sensor code and that the whole throttle body needs to be replaced.
sounds a bit fishy so wanted to get some more info.
i was thinking of just getting a new airflow sensor and seeing if that would work.
Old Jan 27, 2018 | 02:00 PM
BALLSS's Avatar
what code #?
if it is MAF related...its not your throttle body
Old Jan 27, 2018 | 02:34 PM
i didn’t get the code from him, ill take it back up there and get the code number
i was thinking of just getting a new sensor
Old Jan 27, 2018 | 03:43 PM
BALLSS's Avatar
If you have a code for the MAF I don't see why the Throttle Body needs replacing as the dealership said....which is why I asked what code you have...which would point to what may be the issue.
You can buy a cheap OBD 2 code reader so you don't have to take it somewhere to get the code read...and if that shop is even giving you accurate info.
what year/model car?
Old Jan 27, 2018 | 04:01 PM
ok cool ill do that when i get the chance.
and its a 97 trans am ws6
Old Jan 31, 2018 | 10:30 AM
96LT1Z's Avatar
You could potentially have a bad gasket under the plate on the top of your throttle body. This happened to me and my car wouldn't idle right... vacuum leak. I could definitely see this creating a MAF code... cheap fix too.
