Update: Engine knock. Tore the engine down. Pix inside
TLDR: In the end - the issue was the Crower lifters failing, which caused a cam failure. Scroll down for images of lifter rollers and cam. If anyone has any ideas as to what could cause the lifter surface to fail in that way, Karl and I would appreciate your thoughts.
Rearmost cap has some scratches from assembly checking
Cap 2:
Cap 3:
Cap 4:
Front cap:
Rod bearings:
For reference, someone asked to see the oil pump gear on the cam. Here it is - in perfect condition:
I also noticed a lot of oil-scale on the tops of my pistons. I am going to get the heads checked out and make sure the valve seals are good.
The Crower lifters that were installed appear to have failed. I am contacting Crower to see what they think. It appears that some of the external coating on the rollers has started to flake off. Yes, you can catch a nail on these defects. These are Crower 6630 lifters.
And here is the bad lobe on the cam. (CompCams spec'd by Lloyd Elliot) All of the lobes showed excessive wear and damage, but this one was by-far the worst:
Over the years, I have talked with ppl at Comp, Lunati, Bullet, etc and they all agree that if you can feel any of those scratches with a finger nail, that it is starting to wear into the lobes and at that point it is just a matter of time until it wears past the "hardest metal" on the outside of the lobes and into the "softer metal" as it gets further inside.
If the lifters are showing signs of this also, I would expect the same to happen to them.
All it takes would be for just ONE of the lifters or lobes to wear past this hard metal on the outside and into softer metal and then you will have metal ALL in the engine as we go from smooth/hard parts contacing each other to rougher and rougher and softer and softer material as it wears deeper into the lobes/lifters.
I would say if you can feel it with your finger nail, the cam would need to be shipped back to Comp/Lunati and possibly polished if it is very slightly scratched/wounded or just get a different camshaft. Emailing them a pic of the wounded lobe might be enough for them to say if they can repair the camshaft or not and save you shipping $.
I would DEFINITELY replace ALL of the lifters since the pic looks like they are all showing signs of this happening and eventually they will take out the cam lobes.
Since ALL of the lifters look to show that wear, I would guess that the lifters are coming apart on the wheel and that wis causing the lobes to wear.
Judging by the pics, cam doesn't seem to show any wear on the signs from lifters jumping off lobes and crashing back down on side of lobes that you usually see with valve float but I would still check all 16 springs for seat/open pressure so you can eleminate that. This is just based on these pics and not having the camshaft in my hands.
EDIT: IF YOU HAVE CROWER LT1 LIFTERS, I'D ADVISE YOU TO PULL THEM AND CHECK THEM OUT This is based on input from Karl and Lloyd.
I would also replace the cam/lifters ( get it on a billet core) and possibly the valve springs and I'd add an AFR Hydra rev lit for extra insurance. I'd also hot tank/clean the oilpan and replace the oil pump.
+1 the all new bearings, your too deep now to cheap out on a set of bearings..
I had LS7 lifters though, and IMO, the cam was too soft. Either the surface hardness was not up to spec or something. Comp cam here
Got a replacement cam, in billet, from Comp. That's going in probably this evening, along with the rods.
Had the heads checked at a local shop. They were .004 out of true, so I had them surfaced. Everything else with the heads was fine.
Thoroughly checked the pistons, rods, and pins for cracks since I thought that maybe a cracked piston near the pin would also lead to a knock. Everything was 100% within spec.
So, in the end, the bearings were all ok, crank was ok, rods and pistons were ok. The only thing I can locate that could cause a knock was one bad lobe on the piston and all the lifter rollers were delaminating.
The upside is that I was able to clean and paint the frame with POR15 and seal it, and I'll get a chance to install the Dennys driveshaft before it goes back on the road.
