Plug Gap
Old Jun 3, 2018 | 05:48 AM
ak422's Avatar
Default Plug Gap
Swapping out my plugs and just want to be sure that I’m gapping them right. My setup is a large cam, headers, 3.5 exhaust w/ dynomax bullets no cats, 58 mm throttle, electric water pump, etc.
Old Jun 3, 2018 | 09:05 AM
SS RRR's Avatar
Village Troll
I've always went with a .035.
Old Jun 3, 2018 | 01:12 PM
BALLSS's Avatar
gap .050
Old Jun 3, 2018 | 05:43 PM
ak422's Avatar
check your pm
Old Jun 5, 2018 | 09:23 AM
SS RRR's Avatar
Village Troll
Originally Posted by ak422
check your pm
Didn't get anything. What compression are you running?
Old Jun 7, 2018 | 03:52 PM
BALLSS's Avatar
Originally Posted by ******
gap .050
...to elaborate, I recently asked the same ? to Ed Wright. I take his advice seriously. Not only did he say a .050 gap...he said you want a good size spark, not a short gap .035 in a NA motor. Also if emission testing is something you need to deal with, a fatter spark is better, even going to .060.
Regarding heat range, he said stock unless you have closer to 13.xx-14.xx compression then go one range colder. I only have a 11:1 NA motor.
Ed also said when he had his dyno shop he had a bucket full of NGK plugs he removed from cars he was tuning as they exhibited misfire at high RPM's. Said do not run NGK period. Use Autolite 106
There is a lot of info on the internet....thought I would share what I was told by someone who knows WAY more about the LT1 platform and tuning than I and most others do, IMHO.
