95'lt1 going into a 97' M6 ?
Some differences that may need to be addressed is the crank sensor and the knock sensor.
I think you'll need to swap over the timing cover, crank sensor, and crank reluctor wheel, as well as the knock sensor over to the '95 engine.
Didn't know F body OBD2 LT1's only used one KS so if that's the case just use your 97 sensor in the 95 motor. Look up the TQ to tighten it. Don't over TQ it
Yes use your 97 PCM and harness
if you converted to OBD1 you can use the 95 cover. IDK what is involved in converting a OBD2 car to OBD1 but people have done it.
If plug in emissions is a issue for you, can't convert a OBD2 car to OBD 1 and pass emissions plug in test
if motor is buttoned up with 95 TC and hub...you will need to drop front of oil pan enough to remove TC
R&R the hub is not hard. A standard star puller gets them off and you can make a install tool simple with all thread rod, large fender washers, thrust bearing and 1 nut the size of all thread (same size as crank bolt thread)
Last edited by Joe Soucy; Jun 6, 2018 at 11:27 AM. Reason: veryyyyy bad spelling error xD
