Cylinder Head ID - AFR?
Old Aug 28, 2018 | 08:55 PM
25th TA #748's Avatar
Default Cylinder Head ID - AFR?
Is anyone familiar with older versions of AFR heads for LT1s? I bought a car that's stated to be an AFR-headed 383. Without removing anything, I can see "CNC" and "1064" stamped on the front face behind the coil. I can't find a reference online with that combination, but everything else the seller told me about the car checked out so far. I suspect these are early AFRs, produced before they started engraving the logo in the front pad. Can anyone with knowledge of the older stuff confirm?
Old Aug 29, 2018 | 07:33 PM
KW Baraka's Avatar
Have you tried calling AFR?
Maybe drop Tony Mamo (former AFR head designer) a PM?
Just a couple of routes I would follow...….
KW
Old Oct 21, 2018 | 08:05 PM
After looking into it further, these appear to actually be ported stock castings from the defunct CNC Cylinder Heads Inc. out of Florida. I got tripped up initially because 1054 is a valid AFR part number, but for a Gen 1 SBC.
Old Feb 10, 2021 | 08:58 AM
MuhThugga's Avatar
The older AFR heads have an "A" cast by the spark plugs. I have a set of 190s that were discovered to not have the guides concentric with the seats. So, they are sitting as paper weights since it was cheaper to buy a different set of heads.
