Replacing Rods and Crank. A few questions.
...But you would need to pull the pistons off your rods to put on the donor rods....at that point why not also hone and re-ring....and then there is the cam bearings (worth at least a look)
LT1 is rear external balance motor so IDK if donor crank/rods=your crank/rods in terms of balance.
My advice? Leave it alone. You are going to waste more time and money trying to take shortcuts than you will doing it correctly the first time. You aren't allowing any room for incidentals that may pop up, and when no room is allowed, Murphy's Law will be in full effect. Leave the engine alone, save up to have things done correctly, and enjoy what you currently have.
What if I just take a new bottom end, pop out the pistons and ball hone it lightly to clean out the ring ridge? I found a high mileage sbe that runs, but this will be my first time screwing with anything below the deck. Is it safe to just clean up the bores and put everything back after resizing the rods? Assuming all the bearings and other surfaces check out.
I would recommend that this book be your first investment before going any further:
Using a "high mileage" donor motor of unknown condition other than it "runs" to then push 6500 rpm....high mileage bearings (cam, rod, crank) all should be replaced. That means a complete engine tear down with minimally polishing crank and resizing rods with ARP fasteners. Would you be able to just hone and re-ring the cyl.."maybe" but very likely you need a .030 over bore which requires new pistons
Consider buying a short block from ERE or Golen (383 4 bolt forged). I did the later and now have over 40k mi on that motor
I'm just looking for experience from people who have done a cheap refresh, on the off chance that the bottom end I have is still clean.
I would recommend that this book be your first investment before going any further: https://www.amazon.com/Rebuild-Small.../dp/1557883939
Unless you know you have a spun rod bearing or something just leave your motor alone until it does present a problem.
pulling the "bottom end" out because you want rods re-sized with ARP fasteners means the pistons need to come out and those need to go in/out through the top. At that point the motor is completely apart Sure you could just throw the pistons on the re-sized rods keeping the rings and not touching the cyl walls or cam bearings...if you want. IMHO though you may find during this process those untouched items need attention to the point it voids wtf you would just re-size rods and new crank & rod bearings
its your motor & $, do what you want.
Once you spin a bearing you would need to get the crank ground .010 under to clean it up
The metal flakes are now throughout your oil system and will and have started to scratch all the other bearings
You need a new short block rebuild
cheapest path is just slap in a junkyard LT1 so you could drive the car if $ are tight now. Still some $ and time just to do that
Given hw you really want to drive the car, get a 4 bolt forged short block and put your H/C in it
