Trouble with rocker/stud
Trying to install roller rockers
Non self aligning
I have pro comp electronic 2.00 inch over nut 7/16 studs top and bottom.
comp cams high energy 1.6 ratio rockers 7/16
Comp cams lash caps
with the old rocker Clarence by Dremel tool lash caps and guide plates in place I bottom out on the stud before getting enough preload on the lifter 1/2 turn part zero. 1.5 ratio.
Ordered the comp cams rockers in 1.6 hoping that would fix things still bottoming out on the stud before adjustment.
The rocker is hitting on the rocker arm stud shank almost like it is too wide. Anyone have any ideas or a line on studs that will work?
Everyone says measure push rod length I have no clearance to check it and with cleranced rockers it cleans a line right down the center of the stem or lash cap where it is supposed to be.
Thanks for any advice in advance.
The ISKY adjustable guide plates are good for the LT1 heads. Fixed guide plates don't allow each RR to be lined up L-R center on valve tip
update i removed the cheap ebay rockers which were the procomp 1.5 roller rockers and replaced them with a set of Comp Cams Roller Rockers Extreme Energy in 1.6 ratio and i used comp cams lash caps on top of the stems, i replaced the cheap 7.200 hardened procomp push rods with trickflow hardened 7.300 push rods, with everything in place my lifter is rolling on the exhaust valve just across the centerline of the stem, the intake side is rolling just off the centerline of the stem towards the exhaust side, the rockers are finally setting high enough they are not contacting the rocker stud to which they are sitting on, new problem, the billet specialties ball milled valve covers i had were too short, ordered a set of billet specialties TALL ball milled valve covers and everthing looks great now.
