LS1 brake upgrade
I have a 96 F body. I have begun upgrading my brake system with the LS1 calipers, rotors and Corvette brake hoses. The front is done now I am on the rear axle. The plan was to take out the axle shafts from each side of the rear axle. I was then going to put LS1 backing plates on, then the LS1 calipers. Today I was preparing to take things apart to get an idea of what it would be like, but I noticed these teeth on the rear axle halves. I am not sure if the LS1 backing plates will work with these teeth on my current axles. I had no idea these teeth were here. Has anyone experienced this? Can I still use these axles with my LS1 brake upgrade?
Thank you
i have a 96 f body. I have begun upgrading my brake system with the ls1 calipers, rotors and corvette brake hoses. The front is done now i am on the rear axle. The plan was to take out the axle shafts from each side of the rear axle. I was then going to put ls1 backing plates on, then the ls1 calipers. Today i was preparing to take things apart to get an idea of what it would be like, but i noticed these teeth on the rear axle halves. I am not sure if the ls1 backing plates will work with these teeth on my current axles. I had no idea these teeth were here. Has anyone experienced this? Can i still use these axles with my ls1 brake upgrade?
Thank you
Do you have a 4 channel ABS system? It was usually installed in 99-2002 F bodies AFAIK.
Anyway, besides the abs type in your car the backing plates for the LS1 brakes should not interfere with these reluctors.
Awesome, thank you!!
Thank you, will do. They look fine from what I remember, but I'll def check again. Thanks!
