Junkyard Engine questions
I took the valve cover off
Rear end Damage
Pan Looks ok
A couple from their website.
So debating to go pull it. Its late so most people will not see this. Got a few weeks since I am done with college for now as I am job hunting. Very worst case its a return or something I could slap my le2 heads on with a cam and just re-ring the bottom end. My small worry was being able to turn the engine with my 3/8 inch ratchet. You could feel the hits. Pushing up was hard, But most were pulling down with my 230lbs. So maybe its ok. The other kicker is that is a non start car when it went threw the auction. So who knows. Maybe its a pinched fuel line maybe it just would not turn over at all.
Any opinions from you guys.
Right there alone is $2550. There are other things not listed like wiring and pcm. Before you know it a 5.3 swap is an easy 3k. Could maybe sell my t-56 to offset the cost of a ls1 t-56. But I will not going autotragic. No fun in that. Plus I bought my car to be a 6spd.
I forgot how much of a pain it is to pull the engine out of the top Anyways its home. Going to throw it on the stand this week and check it over. Swap over some of my parts and probably my brand new 1k old oem opti and msd wires.
maybe cut the oil filter in half for a quick inspection.
good luck keep us posted.
Today took a look at the bottom end. Pulled a random rod bearing and here are the results.
Debating throwing a set of bearings at it. Might price it out. But everything looks cleaner in the bottom end. Its at least good enough not to really worry about. Good news it is coming apart pretty easy. The exhaust manifolds came off with no broken bolts. So at least its a keeper.
Idea is to get this car going again. Then maybe rebuild the 385 bottom end and le2 heads laying around in the garage. Its easier to work on a car once it runs. Shoot the car has not ran in 3 years. But also has mostly been on and off the road with me only putting 1500 miles on it since 2-21-2009.
