Mighty Mouse Catch Can Plus TorqHead 24X, Where to Move ICM / Coil
Car - 1997 Z28
What - Mighty Mouse Solutions Catch Can
Question - The Catch Can mounts to the driver side head right by the coil and ICM. I’m currently going TorqHead 24X system. I need to know has anyone mounted this Catch Can and where did you mount the ICM / Coil?
Thanks!
Thanks!
Seems like this is solved, but for search history purposes, I just made a small bracket to mount mine to the ABS pump to avoid the coil/ICM. It probably wouldn't work with a standard air intake setup though.
