Sitting 17 yrs...
Initially I checked the coolant and it was full ( looked more like water. I also checked the overflow and there was no sludge on the long plastic piece.
I am picking up the car Thursday and will begin working on it this weekend. First order of business is
1) change oil, filter. ( looks to be a small leak from the filter gasket)
2) drain, flush, refill coolant
3) clean out radiator fins, condenser, etc..
4) change fuel filter
What else should I look for? How can I test the fans as I cannot remember whether or not they came on?
Thanks in advance.
Hope that your rear main, front crank seal, and some other key seals / gaskets don't start to leak once you start driving it. Plan for it, but hope it doesn't happen.
FWIW, I spent about $4k getting the M5 road-worthy after sitting for years.
Edit: obviously change the tires immediately.
Change out that coolant ASAP if everything checks out.
The opti gets a bad rap. Its not made of glass and it is far more durable than you're led to believe on the forums. Nobody comes on here to post about how reliable theirs has been - you only hear about them when they go ****-up. FWIW, there are loads of people running optis for 100-125k with zero problems. Especially a 95-96, which is when GM vented them. In short, a little water won't hurt. Opti-running cars are driven in the rain quite frequently. 1996 is pin-drive on the opti, so it is pretty easy to install. No need to worry about splines.
AC: rent some gauges from Autozone and see what your system pressures are. I'd bet most of your freon has leaked out over the years.
BTW, hopefully your radiator doesn't look like this, OP.
Thats makes 3 of us then. but mine might be a tad darker....or maybe its not and it just seems that way cause i never wash it cause, hah! the hells the point?
