Always Happens
A few weeks back I had an overheating issue and the factory water pump was identified as a culprit. Coolant was leaking profusely from the underside drain hole and I was low on coolant so I decided to order the Mezziere HD water pump and give it a try. After removing the factory water pump, I identified excessive corrosion to the mating surface of the water pump housing so I ran to the parts store purchased a new water pump just to have the housing that I would need for mounting the electric water pump to. I knew I would be changing out the water pump seal while everything was off, but I noticed excessive oil on the timing cover around the opti-seal as well so I stopped what I was doing again and ordered the timing cover gasket kit which included the water pump seal, opti seal, hub seal, and timing cover gasket. Since no other seals were leaking, I replaced the opti seal and the water pump seal only. The crank hub is easy enough to do at a later time and can be done without taking anything off the front of the motor (other than hub) so I'll wait to do that until I notice moisture around it. While removing the plug wires from the opti, one of the plug connectors for the MSD wires separated from the wire and required a new plug wire to be installed so I had to stop what I was doing and purchased all new plug wires figuring it was time anyways. Pulled apart the original opti (~115k miles) and there was no corrosion, everything was dry, so I reassembled it and began buttoning up the front end of the motor. Darn fan shroud wouldn't fit between the radiator and EWP so I wound up shaving off a good portion of the shroud and fan blades to make it fit. Next, I started wiring the EWP and sure as **** the wiring diagram I got for it off the internet was backwards (which probably still would have worked) so I'll have to re-wire that tonight for some peace-of-mind. I start to put intake elbow system back on and wouldn't you know the donkey dong wont fit so now I'm waiting on a 1lE elbow that bypasses the use of the air silencer. I figured while I was waiting on the elbow to arrive I would attack the "low coolant" light on the dash. I removed the sensor to find that the copper sensor was completed corroded with barely anything left of it. Another trip to the parts store and I now have a new low coolant sensor.
Started off as a water pump replacement but ended with 4 trips to the parts store, some online ordering, and replacing more parts than I ever intended to. One thing leads to another and the next thing you know your knee deep with other things you identify as needing to be done. However, I did get to purchase a new puller so its always nice when you end up with more tools than you started with. Its getting to the point where I need a second tool cabinet just for the specialty tools.....birthday maybe?
I see him pushing it out of the garage and walk over ,, figuring first start..
He's all cranked up climbs in and starts the engine.. Sounds perfectly awesome.
Then a high pitched squeal starts,, then really expensive bottom end noises.. and CLUNK
Stops rotating..
I'm staring in the engine bay thinking wtf.. He gets out and I asked,, You did put oil in it,, right?
The look said no..
Yep brand new ramjet 350.. Straight to Valhalla...
I just put my hands in my pockets and walked back home.. Brought a tear to my eye..
Stops rotating..
The look said no..
Had a slight drip at the fuel rail, so figured I would pop fitting off adjust and retighten. (this is after backing car out of garage and down driveway)
Then come to realize with ptfe fittings the brass ferrule is not reusable, and now I can't start my car to get it back in garage.
Minor hiccup in the scheme of things.
