Summer mods Monoblade and stepped headers
Old Dec 13, 2019 | 09:31 AM
396LTX's Avatar
DYNO DAY!!!
Finally time to get results from the mods
I'll post video tonight if not tomorrow morning
Wish me luck
Old Dec 13, 2019 | 09:39 AM
transbird95's Avatar
Good luck!
Old Dec 13, 2019 | 03:45 PM
396LTX's Avatar
484hp 437tq
Not much gain but the extreme wheel spin was killing the torque numbers. My fault tho....went to the dyno with dry rotted tires. Lead plates and cast iron big block heads still didn’t fix it. All the gains were past 5200 RPM where the monoblade could flow more than the 58mm
Old Dec 13, 2019 | 04:12 PM
Colin91Z's Avatar
Originally Posted by 396LTX
484hp 437tq
Interesting. I have a similar combo and have been considering a monblade as well, so good info, much appreciated. Just out of curiousity, did you see any negative effects from the monoblade? Such as slower throttle response, trouble iding, anything like that?
Old Dec 13, 2019 | 04:24 PM
396LTX's Avatar
Throttle response is better......almost too fast. I’m having to relearn how to drive the car becuz of the amount of air rushing in with the bigger blade. Idle did have to be recalibrated but that’s what tuners are for.
Old Dec 13, 2019 | 04:29 PM
Colin91Z's Avatar
Good to know. Sounds like there isn't really a downside to it even if the gains are minimal. I was worried that the idle might suffer because of eliminating the IAC feeding the built-in idle circuits in the manifold. Thanks for the info.
Old Dec 13, 2019 | 06:24 PM
Vicious95Z28's Avatar
The mono blade has crossed my mind several times, with 7000 rpm shift points correctly and the proposed solid roller build in mind with LS PCM conversion, 7500-8000 could potentially be my rev ceiling. I can see the mono blade being a benefit.
Old Dec 13, 2019 | 09:30 PM
Fast355's Avatar
Really needs a 4" air intake and a LS7 cartridge MAF in a 100mm housing to do it correctly.
Old Dec 14, 2019 | 09:13 AM
SS RRR's Avatar
Village Troll
484hp 437tq
Would love to see the dyno sheet. Planning on taking it to the track?
Old Dec 14, 2019 | 10:21 AM
I wasn't going to leave that part out of actually doing it, brotha... I just didn't mention it.
Old Dec 14, 2019 | 01:26 PM
Fast355's Avatar
Oh I forget. A MAF upgrade is a dirty thing around here. Actually getting an abundance of air into your engine.
Old Dec 14, 2019 | 10:11 PM
  #32
396LTX's Avatar
Old Dec 15, 2019 | 12:03 PM
  #33
PARMY's Avatar
What was all the smoke in the vid?
Old Dec 15, 2019 | 12:45 PM
  #34
396LTX's Avatar
Wheel spin dude....those tires have no grip anymore
Old Dec 15, 2019 | 01:05 PM
  #35
Tires were screaming like a banshee being raped by the devil!
  #36
396LTX's Avatar
Hahahaha yea!
Old Dec 15, 2019 | 06:28 PM
  #37
I'd be really interested to see what your setup would do with the LS lid conversion and CHRS1313 man. I've spoken to Lloyd about my SR setup several times and one thing he consistently brings up is the intake style. He was the main reason that I went to the setup years ago and I can honestly tell you that it made the big end pull way different. It felt like I had done a cam swap again. It gave me a legit additional 300rpm of actual pull on the shifts that I never expected and from about 4800+ it felt like a different car. That was before the CHRS1313 Ram Air. The way the car pulls with it just blows me away.
There's been a lot of bickering back and forth between members here on intake parts, tubing, MAF & throttle body size etc. From the experience I've had with my car thus far every single time I'm able to shove more air to it, it just gets better which is why Chris (Fast355) and I will likely soon get together on an LS7 MAF and a bigger lid. I want to see what it will do with my current setup and I'm absolutely convinced that above 7000 with a solid roller it's going to really shine!
Old Dec 15, 2019 | 07:16 PM
  #38
396LTX's Avatar
Interesting......well we actually did do a pull on speed density with no intake and it actually lost power. I figured it was due to air turbulence. No intake to funnel the air to the TB
Old Dec 16, 2019 | 11:39 AM
  #39
StealthFormula's Avatar
The power your car makes is impressive especially given the 10.5:1 compression and 91 pump gas limitation.
Old Dec 16, 2019 | 12:30 PM
  #40
Shownomercy's Avatar
Man-Crush Warning
You need some form of bell mouth. Although the super stock guys run open TB I believe?
