Bolt on estimate
I was gonna say low 14's but without a time slip its hard to say what's really going on. Getting my stick car into the 10's N/A would be nice but I don't see that happening anytime soon.
FWIW my car drives better in the rain/snow with a 10" 3k stall than it did with the stock one. If your current converter is a 12" unit you might want to consider going with something smaller, even if the rated stall speed is the same.
Handy little sight. IDGAF when I used to live in Texas and VA. Now that I'm at a higher elevation, the last time I went to the track it was 100* and DA figured out to be around 9,000ft. ele. Sad!
The conversion chart I used caps out at 6000', applying it to your ET gives a sea level equivalent of 13.33. http://wallaceracing.com/altitudecorrection.htm
Take that number with a grain of salt...
Not used to seeing much over 3000' DA conditions personally.
