Lt1 weird issues
That picture is the wire coming from iac sensor on the intake, but I see that the temp sensor also mates with same harness. I would think that would cause issues to the temp sensor cause the wire connects to it? correct me if I'm wrong.
This is the connector that goes into the ECT sensor (Engine Control Temp) sensor in the wp. Seem like the wires are kinda messed up. I wrapped it and the iac sensor (Previous photo) with electrical tape.
You see the difference in the top part (Crown I would call it) the hypertech might be more restricted. Idk just more theory.
Look at the height differences. Mishimoto left, hypertech right
Here a Pic of mishimoto and the stock 180. Look more similar and height and size. And the crown is the same. (Sorry for the lightning)
You can ohm the temp sensor to see if it corresponds to the temp/ohm range noted on this grid
courtesy of shbox
http://shbox.com/1/4th_gen_tech2.html#ect
courtesy of shbox
