What caused fried PCMs?
Not a tuner, but here's two:
1) Flashing an ECM with a bad or low battery. This is one of the most guaranteed ways of bricking an ECM.
2) Interrupting a flash. Flashing can take anywhere from 2 to 20mins. When you start flashing, do not play around with the laptop/scantool or work on the car. It takes one little mistake to knock out a cable or unplug a loom to interrupt flashing and ultimately kill the ECM.
I'm sure there are others.
The following users liked this post:
LTx383 (02-14-2022)
Hello,
3 - Other modules and devices operating on the CAN bus that don't go to sleep or can't be commanded to sleep / quieted. This noisy bus traffic makes the PCM update harder to accomplish and I rarely write to a PCM with it installed in the vehicle. A bench harness for doing the update is best using a good, three amp, 13.8 volt power supply and I've only ever written to a PCM installed in the vehicle one time . . . it worked.
Rick
Rick
LTx383 (02-14-2022)
