LT1 Rebuild & Swap into 3rd Gen
Old 03-01-2023, 10:06 PM
  #201
Supercharged111's Avatar
I bet it chugs along fine with that much grunt. Backing up on the other hand. . .
Old 03-02-2023, 01:41 AM
  #202
64GunPilot's Avatar
Originally Posted by Shold89
Lovely build !
Thanks man. More work than I ever imagined. Don't want to be doing this again anytime soon. We'll see if it holds up to this weekend's torture.
Yea....but even when I flat tow my Suburban behind it, you can't backup period. Can't backup with the Kia on a towdolly either. So.....same same....Just longer.
Old 05-08-2023, 01:18 AM
  #203
64GunPilot's Avatar
My power steering is causing me much agony. The power steering pump whines no matter what I do. I've replaced the pump three times, I've chunked the Impala Pwr Str line and replaced it with all -6AN PTFE hose and fittings, replaced every o-ring more than once, Ive even replaced the power steering gearbox, bled the system several times lock to lock, replaced the reservoir as well (from the Astro Van I stole the intermediate shaft from)
I've gotten it to be 100% quiet for about 3 minutes after engine start up, and then again it starts whining. The fluid in the reservoir has a bunch of bubbles. I've eliminated all fluid leaks.
Any suggestions?
Is my 4th gen pump just not gonna work with re-circulating ball steering gearbox? I wish I could use my old 3rd gen pump but it wont fit in any capacity.
Old 05-08-2023, 11:50 PM
  #204
64GunPilot's Avatar
Ok, thanks for the advice people. Figured it out on my own. Tightened up some clamps from the reservoir to the pump and put a couple more oz of fluid and now problem is completely gone. Calling this a win.
Old 05-09-2023, 11:32 AM
  #205
Village Troll
SS RRR's Avatar
LOL... All I had was that if there are still air bubbles it had to be getting in somewhere, but figured you already knew that? :shrug:
Old 05-09-2023, 01:55 PM
  #206
shakenfake's Avatar
How is y'all's brake fluid so nice. Mine is always just black
Old 05-09-2023, 08:53 PM
  #207
64GunPilot's Avatar
Sometimes I like to take the long way to the solution lol. I drove around the neighborhood and let it idle for an hour today. Solid fix.
This is a racecar. I flush and bleed the brakes before every event. So……even after one event it sometimes starts to turn colors on me. Using RBF600
Quick Reply: LT1 Rebuild & Swap into 3rd Gen
