Rocker Arm Stud Torque?
when I screw the studs in they bottom out in the base of the threads , can you torque a stud down at the bottom or is it gonna cause stress cracks or fractures?? They are iron heads.
Ask a machine shop about it.
collarless studs were what vortec heads originally came with "pressed in" but these are aftermarket vortecs which have threaded openings to receive rocker studs.
the whole stock valvetrain was set up to use those shoulderless rocker studs unfortunately on the 5.7 vortec.
Didn't have this problem when i built my lt1 obviously. I used 3/8 arp studs on that mild build with the crane 1.6 RR'S and has been smooth as butter for 35k
