Would you guys worry about how the seal wore into this crank hub? I sanded it down the best i could with some 320 grit to polish it up. It's barely catchable with a fingernail.
Thanks guys, yeah i installed it and figured what the hell it's worth a try it didn't leak before. If it does I suppose i will have to pull out some dimes and buy a new one.
It also helps if you don't drive the seal to the exact same depth as the original, so the seal isn't hitting the old groove..
The seal I got recently had a note NOT to lube it.. They want it to start dry ..
Speedy sleeves work great, I use GREEN locktite.. I don't want it to move.. without fire...
LOL
The seal I got recently had a note NOT to lube it.. They want it to start dry ..LOL
that seal would be a PTFE seal, and yes, they install dry. Front and rear main seals, and others are offered in rubber or PTFE with the latter being a newer type used now more commonly. The WP drive seal has always been a PTFE seal
Speedy Sleeve is a common fix for grooved damper hubs...but IMHO hubs are readily available and also come keyed which IMHO is better than just the stock "press on" type. A machine shop can even key a non-keyed hub
