96 LT1 PCV upgrade
Old Apr 1, 2024 | 05:41 AM
Dren's Avatar
Default 96 LT1 PCV upgrade
Wondering if anyone is running a Wagner PCV on an LT1? If so, how’s it working out for you?
Old Apr 8, 2024 | 06:06 AM
tallrandyb's Avatar
yes, needed it with very large cam. Just follow the instructions for tuning it based on your vacuum levels and it should work fine. I’ve got it routed to a catch can also.
Old May 14, 2024 | 07:28 PM
Steve40th's Avatar
Never heard of this, interested in knowing what it did for you, and why you chose it?
Old May 15, 2024 | 02:10 PM
tallrandyb's Avatar
Stock PCV's are selected/designed to work within the stock vacuum signal ranges for stock engines. Once your vacuum profile changes (bigger cam no longer pulling the same vacuum as stock ranges for example) you can use an adjustable one like Wagner to insure you get the ventilation when you want it.
