grantelli maf
Old Sep 10, 2004 | 11:20 PM
stone150's Avatar
Default grantelli maf
is it worth it to replace my MAF with a high performance one, my performance guy said not too.
Old Sep 10, 2004 | 11:59 PM
qqwqeqwrqwqtq's Avatar
He is right. Stock maf is the way to go.
Old Sep 11, 2004 | 12:02 AM
'97SLVRBullet's Avatar
Why would you pay 300+ for something you can do with a dremmel?
The only thing you will do to your MAF sensor with a dremel is ruin it.
Old Sep 11, 2004 | 12:23 AM
5432LT1's Avatar
-w3rd-
Old Sep 11, 2004 | 12:27 AM
Try it and see, I have no problems with mine whatsoever.
Old Sep 11, 2004 | 02:21 AM
TwoFast4Lv's Avatar
There is no gain there other then a scewed tune up
I did a ton of this stuff years ago. Right now I am running MBA MAF ends and Stock electronic with a custom tune. Took me a while to figure out the tables but they are easy to do now
The best is just to use a stock MAF that has not been butchered Some say the screen has a reason to be there but we have always dyno'd a hair higher with out it.
If you hack up your MAF with out tuning on a 96 up car you may regret it
Old Sep 11, 2004 | 08:47 AM
Z284thgen's Avatar
i just put a maf of an 03 Z06 85mm with the stock one a/f was 13.-13.5 across the board
with the Z06 a/f was 10-10.7 across the board so i had ed tune for the new maf and havent been back to the dyno yet to check the a/f
Old Sep 12, 2004 | 10:59 AM
stone150's Avatar
i have herd about switching to a zo6 MAF what are the advantages? and would it just be wiser to get new MAF ends?
Old Sep 12, 2004 | 11:05 AM
shaneSS's Avatar
I had the 85mm MAF and it jacked my **** up bad. a/f went to 10.1 in some cases and caused me to have a pretty good amount of KR up top. I switched to some billet ends on a stock MAF and it works great.
Old Sep 12, 2004 | 11:19 AM
96capricemgr's Avatar
Listen to TwoFast4Lv and reread what he said, even new ends on the stock electronics needs recalibration in the pcm.
The stock pcm can not understand the ZO6 sensor at higher than about 350grams per second and the stock f-body sensor it can understand up to about 450grams per second, making the LT1 f-body sensor the best choice. IF you know what you are doing then the calibration for the ZO6 MAF can be done and you can rapm up the fueling based on map and RPM past the 350gps but basically what you are doing then is trying to make the thing work speed density , why overcomplicate things.
As I said on another board, all the Granatelli or even s hacked stocker does is report FALSE info to the pcm, if you have the stock too rich pcm setting this can result in a temporary power gain but the O2s will help the pcm learn it out. Much better to dial in the AFR through the pcm and leave the sensor alone.
Old Sep 12, 2004 | 02:28 PM
5432LT1's Avatar
When i get my heads and cam done im gonna trailer it down to ed wright and have him dyno tune my 93. whats his website?
Old Sep 12, 2004 | 07:24 PM
Z284thgen's Avatar
www.fastchip.com
