Cam with stock heads....
Old Sep 19, 2004 | 11:25 PM
OneMeanZ's Avatar
Default Cam with stock heads....
I would like to know what is the best cam for stock heads...I just don't have the money for heads right now.
I was thinking about the LT4 Hotcam kit, or does Comp make a good grind that would work well on stock heads, with LTs. THanks
Old Sep 19, 2004 | 11:34 PM
94Formula/TA's Avatar
*cough* 847 cam has made 360+ RWHP on stock heads *cough*
Rich
Old Sep 20, 2004 | 01:59 AM
72chevy2's Avatar
xe 233/239... with stock heads, stock intake, full weight hardtop with 100 shot, lt's, tb, k&N, msd and M6 with a stock 10 bolt... went 11.47 at 124 on 3.42's and nittos
the car has never been on a dyno and sat door to door to a 500whp trans am 100shot for 100shot.... so you can say its around 400 on motor to the wheels... possibly a lil more considering the t/a the car ran had weight takin out
Old Sep 20, 2004 | 07:36 AM
SSmoky01's Avatar
Why not just port your heads yourself??? It ain't gonna hurt anything, and ain't hard. Just takes time and patience. Comp Cam 305 or 306 would be great choices. I think the 847 would be a little much unless get a 52 or 58mm TB, bigger injectors, etc. You might be alright though.
Old Sep 20, 2004 | 08:03 AM
ROFL 400 WHP with stock heads. Guy's its a little challenging to get 400RWHP with heads and cam.
Rich
Old Sep 20, 2004 | 08:08 AM
shaneSS's Avatar
The F13 is sick for stock heads and beter than jsut peak #'s the power under the curve is insane. CHeck it out at FUTRAL. the specs are 230/232 585/595, I got mine on a 112 +4 to try to salvage soem low end torque.
Havent been on teh dyno yet but these cams have made 400 rwhp on stock heads and are very stretable. Plus you have an M6 so no worries there.
cheers
Damn! just realized you are an LT1. My bad. just ignore my rambling.
Old Sep 20, 2004 | 09:08 AM
SSmoky01's Avatar
Rich just take it as you will. You know some, well alot, of people are gonna stretch the truth.
Old Sep 20, 2004 | 09:32 AM
S8ER95Z's Avatar
Originally Posted by Casper97
Why not just port your heads yourself??? It ain't gonna hurt anything, and ain't hard. Just takes time and patience. Comp Cam 305 or 847 would be great choices. I think the 306 would be a little much unless get a 52 or 58mm TB, bigger injectors, etc. You might be alright though.
Isnt the 847 larger than the 306???
Old Sep 20, 2004 | 09:41 AM
SSmoky01's Avatar
I fixed it. I think the 306 has more lift ,exhaust side anyways right?
Old Sep 20, 2004 | 01:56 PM
Jordan57's Avatar
The CC306 and 847 would both be excellent of the shelf choices. Might as well only do a cam swap once right? The springs need to be changed with almost any cam and a set of adjustable roller rockers arent a bad idea either. As far as a bigger t/b you can port your own to a 52mm and port the t/b to match it. Not really a big deal, and as for the fuel injectors...the stock ones are fine for that application...if you spray down the road then injectors should be replaced. We swapped in a cc306 in my buddies 97 lt1 vert....(30thz28) and it ran like a raped ape. If your an auto...you will want a stall and some gears....or if your a m6 get some gears....tuning on an auto is a must...but it will run decent w/o but for max hp get it tuned. A cheap mail order tune will do wonders pcmforless is highly regarded on this board. Good luck.
Old Sep 20, 2004 | 01:57 PM
Vendetta's Avatar
the 847 and the 306 are almost identical. I have never before heard somebody suggest one and say not to go with the other. There are minor differences, but saying "Go with the 306, but the 847 is too rough" doesn't make any sense. The 847 is a bit more aggressive, but not by much.
Don't touch the heads if you don't know how to port. Don't even try it if you don't know what you're doing.
Old Sep 20, 2004 | 02:06 PM
OneMeanZ's Avatar
Would it be okay to put a cc306 in the car with the stock heads??
Could I make more power over the hotcam even know the heads are choking it off?
Old Sep 20, 2004 | 02:07 PM
Jordan57's Avatar
enis guy lives!!!!!!!! I thought u died man...lol. Yes they are very close in size. The gm847 is a tad larger but not by much and can usually be had cheaper....209 from Jason Cromer.
Old Sep 20, 2004 | 05:34 PM
brandboZ28's Avatar
Im running the xe 227/233 in my stock headed motor. One thing that I suggest is to go big the first time, even with stock heads. No need in changing cams twice.
Old Sep 20, 2004 | 05:40 PM
SSmoky01's Avatar
brandbo is that what you dyno'd before cam? Those are great times for stock!!!
Old Sep 20, 2004 | 09:05 PM
brandboZ28's Avatar
No, both the dyno numbers and the times are with the cc305 cam. The dyno #'s are untuned and the ET was with a PCMforLess tune. Im now running the xe 227/233 and havent gotten the weather to beat those times but that should be just around the corner.
Old Sep 21, 2004 | 10:34 PM
72chevy2's Avatar
Rich
come to north carolina and see it.... available anytime
Old Sep 21, 2004 | 10:43 PM
DietCoke's Avatar
Not happening, even in Texas
Old Sep 21, 2004 | 11:44 PM
72chevy2's Avatar
http://maps.yahoo.com/dd_result?ed=x...Nc&tcountry=us
come on with it then... you can run em against your heads and cam, then i'll pull the intake off to show you stock, unported heads and intake..... afraid to get your feelings hurt?
Old Sep 22, 2004 | 08:41 AM
Elysian's Avatar
I run a 233/239 cam with heads flowing 280cfm @ 0.6 . . . had it on a Mustang Dyno not too long ago and hit ~380rwhp. With a electric water pump, some underdrives, and 1.7 rockers, I might be able to hit 400rwhp. Granted, if I put the car on a dyno-jet instead of a Mustang dyno, it probably already passed 400rwhp, but not by much. Unported factory LT1 heads flow ~215cfm on a good day. The less the heads can flow, the bigger the cam you need to make the same power - and the higher the rpm. Given that the LT1 computer is limited to 7200rpm, I would be impressed with any stock LT1 headed car hitting 400rwhp without a blower or NOS. If you happen to own one of the 100 or so factory LT4 powered Camaros or one of the Grand Sport Vettes, it MAY be possible to hit 400rwhp cam only. Even then, it would have to be a significantly bigger cam than what I'm running (possibly solid roller) and you would need all the boltons money can buy. Not saying it isn't possible, just not very likely.
