F Body Engine Removal
I DO pull the trans off the engine first but know people who leave it.
Once it is all loose you come up to the cowl then forward to the radiator support. next you twist the engine 90 degree's then finish coming up and out. Tie every thing off close the hood and push it out of the way
Good luck man!
http://ken.lowrance.com/Projects/Hea...ineRemoval.htm
http://www.michiganspeed.com/enginepull/index.html
http://camaroz28.cardomain.com/memberpage/348183/6
Do you have to pull the motor out to change the motor mounts out?
