New TY TECH LT4 is in!
Old Sep 21, 2004 | 08:21 PM
Stefan D.'s Avatar
Talking New TY TECH LT4 is in!
The new piece is in . The car will be ready this week for some testing and will keep everyone posted. Motor is still the same with a little, little more compression and some other minor changes. Will definetly be at THUNDER.
Attached Thumbnails New TY TECH LT4 is in!-transam-001.jpg   New TY TECH LT4 is in!-transam-00mot.jpg
Old Sep 21, 2004 | 08:54 PM
got_hp?'s Avatar
specs?
Old Sep 21, 2004 | 10:29 PM
clyde moore's Avatar
Looks good Stefan It will be cool to see it run at Thunder.... Us LTx guys need to stick together
Old Sep 21, 2004 | 10:36 PM
DietCoke's Avatar
Interesting. What kind of heads are those? Strange header bolt pattern.
Old Sep 21, 2004 | 10:39 PM
Parker TX's Avatar
Lookin good from here!
Old Sep 22, 2004 | 12:19 AM
Dave95Formula's Avatar
Headers are Hedman 1 7/8"...they have adapters allowing the header bolts to be moved away from the header tubes so the tubes don't have to be crimped to clear the header bolts.
Dave
Old Sep 22, 2004 | 12:37 AM
BizZzatch350's Avatar
Moderator
Awesome, cant wait to see it at Thunder.
Old Sep 22, 2004 | 02:28 AM
METALBEAST's Avatar
Good luck at Thunder. Make the LT1 name proud
Old Sep 22, 2004 | 02:57 AM
riddler's Avatar
Veteran: Air Force
Very Slick, good luck at Thunder
Old Sep 22, 2004 | 10:27 AM
got_hp?'s Avatar
Dave
but thats a totally different bolt pattern than lt1/4 heads.........do you have converted sbc heads on there?
Old Sep 22, 2004 | 11:30 AM
MADMAN's Avatar
LS1Tech Sponsor
Stefan your cheating. Tell them you put the sb2.2 heads on so they will understand your headers.
__________________
www.madmanandcoracing.com
225-343-9029
Old Sep 22, 2004 | 12:04 PM
SSmoky01's Avatar
Oh yeah, that is slick. I can't wait to run you, I mean, see you run at thunder. Nice build!!!
Old Sep 22, 2004 | 05:56 PM
I have a set of the headers on my 392 with LT1/LT4 AFRs. There is an adaptor plate you bolt to the head first with countersunk flat headed allen bolts. You port the plate to match your exhaust ports and then bolt the headers to the adapter plate. The adapter plate moves the location of the header bolts so they do not interfere with the header tube.
Dave
Old Sep 22, 2004 | 08:30 PM
taner's Avatar
8 Second 6 Speed Director
From: windsor, ont. canada - Home of the fastest LT1 6spd.
looks great! c u at thunder!
Dave
sorry to ask, but who makes and sels the relocate kit?
thanks
taner
Old Sep 22, 2004 | 08:39 PM
Stefan D.'s Avatar
Guys those are LT-4 heads with HEDDMAN headers and adapter plates. I went to a bigger header and those are the only ones that were 1 7/8th with 3.5 inch collectors. They allow for more clearance when using head studs also but it seems that the plug clearance is tight and first glance. Also one collector is against the floor so I have to see whats up. See if this pic helps.
Old Sep 22, 2004 | 08:41 PM
taner's Avatar
is plug access the same?
thanks
taner
Old Sep 22, 2004 | 09:00 PM
Stefan D.'s Avatar
Taner, its looking a little tighter but I just might need a different tool selection than the ones I used on my Hookers. I will let you know when I get the car back how it is.
Old Sep 22, 2004 | 09:25 PM
Z8'S's Avatar
I run the same headers on my car all the plugs are great .............except I have to remove the driverside header to change #5 But they remove very easily.Still trying to come up with "special tool" for easy access.
You testing this weekend Stefan? gimme a call
Old Sep 22, 2004 | 09:59 PM
Birdie2000's Avatar
At what point on a blower engine would you guys say these things become desirable? Stock cubes here with 15+ psi boost. Camshaft 236/243/114+4.
Old Sep 22, 2004 | 10:07 PM
Stefan D.'s Avatar
Chris whats up, I will give you a ring this week. I waiting to get the car back then gonna try and fit some 28x10.5 Ws. MADMAN said they will fit with some banging and SWEARING Hope all is well.
