New TY TECH LT4 is in!
Old Sep 22, 2004 | 10:14 PM
clyde moore's Avatar
Z8's I have the same headers and use a cut off sparkplug socket with a notched side, using a 3/4 stubby wrench. After that it just falls out of there(cussing and swearing)
Old Sep 22, 2004 | 11:01 PM
Dave95Formula's Avatar
Originally Posted by Stefan D.
Also one collector is against the floor so I have to see whats up.
The one collector that is on the floor wouldn't be the driverside would it? Mine is pretty much touching the driverside floor. You also might give a look at the clearance of the k-member with the passengerside header. I have a BMR k-member and one header tube is touching the rear innermost point of the frame stand of the k-member so the header is coming back off and the k-member getting notched just a bit.
Dave
Old Sep 23, 2004 | 12:40 AM
TwoFast4Lv's Avatar
does this help?
18* LT1, bare
Old Sep 23, 2004 | 10:10 AM
got_hp?'s Avatar
are your motor mounts worn?
our driver side mount stretches, and the passenger side crushes, this makes the driver side collector raise up and hit the floor sometimes, and the passenger one hangs lower.
i had that prob and put in new motor mounts and everything lined up fine again.
ELLIS.........stop making me drool.......i want your engine! whens it going in?
Old Sep 23, 2004 | 10:33 AM
Joe Overton's Avatar
Looks good Stefan ... better watch it, you might get accused of running 18* heads because of those stahl adpaters..
Old Sep 23, 2004 | 10:36 AM
RealQuick's Avatar
Stephan, did you use install the mottor with the headers on using the happy hooker. I have a happy hooker and was wondering how much of the engine i could assemble and still drop it thru the top. thanks.
Jon
Old Sep 23, 2004 | 03:12 PM
DietCoke's Avatar
Jon
WEll ah, seeing as it bolts on top of the intake, that'd be all of it.
Old Sep 23, 2004 | 04:12 PM
Stefan D.'s Avatar
Mounts are solid Moroso so I dont think that is the problem.
Old Sep 23, 2004 | 04:13 PM
Stefan D.'s Avatar
No I did not install it with the headers on it. I was just fitting them for the head studs when the pic was taken. Assemble the whole motor minus the fuel rails and it wil all go right in.
Old Sep 23, 2004 | 06:26 PM
Brady's Avatar
LS1Tech Sponsor
no you silly bitches, those are 15* heads milled to 13.25* (I know what I'm looking at)
__________________
1966 Chevy II twin turbo LS3 project
2016 Z07 Carbon
Old Sep 23, 2004 | 06:54 PM
RealQuick's Avatar
Thanks.
  #32
RealQuick's Avatar
Thank you.
Old Sep 24, 2004 | 06:37 AM
  #33
taner's Avatar
8 Second 6 Speed Director
From: windsor, ont. canada - Home of the fastest LT1 6spd.
Originally Posted by TwoFast4Lv
does this help?
18* LT1, bare
man that intake setup is just f'n amazing! i really like the way the fogger nozzles were installed and lines plumbed!!!! got a spare 23* intake lying around for sale
i have to save a copy of that pic!
Old Sep 24, 2004 | 01:49 PM
  #34
cenman's Avatar
what valve covers are you using?
Old Sep 24, 2004 | 02:30 PM
  #35
Brady after A second glance they do like 15* hmmmm.....
Old Sep 24, 2004 | 03:16 PM
  #36
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Nice.
Stefan, treat yourself to one of those solid elbows you're worth it baby!
Old Sep 24, 2004 | 10:49 PM
  #37
Stefan D.'s Avatar
Nice.
You mean the ones that hold all the heat. No my 1LE works fine, plus thats for you high-tech supercharged guys.
Old Sep 24, 2004 | 10:50 PM
  #38
Stefan D.'s Avatar
TY TECH had them made about 3 years ago. I ask who did them and let you know.
