Lifter question
Are these shot lifters?? I'm still chasing my same problem for over a year now and it's starting to wear thin.
IF it was a collapsed/shot/ect lifter, the valve wouldn't open all the way, not as much air would get in, and there would be a rich condition shown on a sacnner, correct?? This could also be associated with a low RPM cutting out with a fast WOT movement due to excess unburned fuel in the mixture, correct?
I forgot to add that every now and then the car would get a hick up at lower rpms from this as well, seemed like the ignition would cut out for a split second however it went away after the lifters were changed.
