Someone help
Old Oct 19, 2004 | 07:42 PM
Hambone 7's Avatar
thunder racing and summit, almost all racing parts distributors sell cheap wire loom kits that keep wires of f headers.
Old Oct 19, 2004 | 07:47 PM
S8ER95Z's Avatar
Well glad to see you found the issue!!! (Wont be needing those injectors anymore I take it ?? )
I routed my wires UNDER the old metal braket on the block. I also used twist ties to try and keep them away from the headers. I have some arcing but my wires are completely stock (119K on them, I will be replacing them this week) so I think they just got old.
Let me know what you guys figure out. Its a pita to route those wires.
Old Oct 19, 2004 | 09:02 PM
LS1racer346's Avatar
not sure if we'll need the injectors or not.. i cant imagine the plugwires making it dump more fuel than normal and get literally 3 to 5 mpg... we'll see
Old Oct 19, 2004 | 09:33 PM
SAPPER's Avatar
well, if this helps any and if you're realy into doing it. I buy my wire, teminals, boots, etc in bulk. I custom make wires for guys w/ f-bodys that have L/T's. I run them long enough to come up through between the tubes and use an assotment of colored or just black zip ties to separate them. A little trick. Wrop one around the wires, and one in between each wire, around the first tie and tighten all. Looks cool and is an awesome looking deal. Any stock made wire is not long enough to go past each tube and come up through to clear the tubes.
Old Oct 19, 2004 | 10:22 PM
S8ER95Z's Avatar
How much do you charge for wires?? I have shortys though...
Old Oct 19, 2004 | 10:54 PM
we were thinking about this...
http://www.thunderracing.com/catalog...vid=4&pcid=104
at the bottom.. its a kit that routes the wires on top ... on the valve covers.. looks kinda cool.
